9m restoration of "Kermit" (1990 Championship winning 964 Trophy Cup)
#226
The rear rotors are stock 964RS, presumeably 24mm & we've not weighed Kermit since it was finished, but the last time we did I think it was sub 1100kg without fuel.
#227
I am in the process of converting my brake system to a Cup setup. I have sourced a set of 965 rear calipers and am told that in order to get them to work properly with the 24mm wide rotors one needs to machine the calipers down so that they are narrower. Would you happen to know if I need to take 2mm off each caliper half or if I just take 4mm off the inner or outer half?
From what I have been told, this is what the factory did but I can't find any documentation on exactly how the procedure was done.
Cheers, James
#228
Great, thank you Colin.
Cheers, James
Cheers, James
Best,
Thomas
#229
Thomas, thank you for the information. Yes, I have the 965 rear calipers which have the larger pistons so I'm all set in that regard. Sounds like I can just use a 2mm thick washer to space the calipers out correctly so they are centered over the rotor.
Since i have a shop at my disposal though, it sounds like 2mm needs to come off each caliper half, according to your findings and setup.
Cheers, James
Cheers, James
#230
Cheers, James
Cheers, James
#232
#233
Colin, If you don't mind, can you post some more pictures of the brake fluid bottle? I have the larger one at home but would like to see how the plumbing runs so I can install mine correctly.
Cheers, James
#235
Thanks Harald, that would be much appreciated (as a non-German speaker PSL is definitely not a magazine that I would normally look at). I have got the odd copy of Flat 6 (French) but just I'm kidding myself that I can understand some of it!
Glad that you are enjoying the builds, lots more to come!
I'll put it in the mail this weekend!
#240
All that Olaf could confirm to Charles was that the cars were owned & run by the Derkum team which unfortunately no longer races, since the team had all the records of the cars he could not help. The lack of evidence was not news to us, this had been confirmed by Olaf a couple of years ago when interviewed by a journalist we know in relation to an article he wrote about Kermit.
The article which was obviously written before we started the restoration and unfortunately never got published because the magazine were not happy with the photos of the car at Oulton Park. I've got a copy of the article and I am trying to get permission for Tony Carey to include it in a forthcoming revised issue of the 964RS resource book.
