A Carrera on my desk - UPDATED
#77
Technical Guru
Originally Posted by AOW162435
It's certainly possible - if I make another batch. It's as easy as soldering a continuous wire to each of the warning light pins - and tying that in to a separate light switch.
#79
Technical Guru
Do you have a pic of that part - how large is it?
Garrett's photo of the warning buzzer
but unfortunately it is attached to the central informer which also doubles as the, "machine that goes ping". There might also be relay involved I've just never had a reason to go digging so I'm not really sure.
#80
Seared
Jason,
If you find out more info on the buzzer, let me know. The item by itself could easily be incorporated into the side of the clock housing. Making it functional is the puzzle.
Andreas
Andreas
#81
Andreas,
I'm sure you can source out some cheap, metal embossing numbers and then hammer it into the underside.
Here's a start: http://www.argontool.com/ecatalog/frames/default.asp
#82
Burgled
Originally Posted by JasonAndreas
The speaker for the, "oh sh*t something expensive is about to break" warning buzzer is real small.
#83
Seared
Mark,
I actually searched for some sort of branding iron with interchangeable numbers. Each possibility I found was way too expensive for the limited use I needed. In the end I found a Dremel electric engraver. It works, but it's impossible to form perfect numbers with the varying hardness of the wood grain.
The small impact stamp shown on that site may have worked well though.
Andreas
Andreas
#84
Mark,
Actually, the company that milled the wood blanks sent the finished pieces to another company that laser-engraved the logo I designed. The seriel numbers are done by me with an electric engraver - not quite as nice![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Pete,
Andreas
Pete,
Andreas
I have a heated "iron" that I use to brand my work for posterity and it never comes out that sharp.
Hmm... laser engraving.. new tool?....
#85
Seared
Mark,
I'm all for new tool purchases, but a laser engraver? The clocks would need to fetch $1,000 for that to happen
Andreas
Andreas
