Pending projects and a few q?
#46
Professor of Pending Projects
Originally Posted by Smokin
Jaime... You're my freakin' HERO! Would you mind if I asked where you got that and approximately how much you paid? I'd LOVE to have one of those! Is it electric/hydraulicr?
That is Slick with a capital "S"!!!
All info and more photos here: Mid-raise lift
Delivered to my home in Orlando, FL - US$1,400.00 + 98.05 to have the truck that came home with a lift... 1200lbs delivery weight... If you have the ceiling height I would recommend a two post asy lift... only a couple of hundreds more and soooooo much better (nothing in between or under the car which makes it even better to work under our cars).
#48
Originally Posted by mxbanker
How are those strut braces for cab's?
#51
Originally Posted by jimq
Jaime
How high is your ceiling in the garage? Higher then standard? Darn I may have to find out where you live
#52
Originally Posted by Marc Shaw
Okay, got the rocker panels repainted and the sill trim changed and all put back together -- fuel filler neck is next.
Marc
Marc
That is great Marc!
I have all the parts... hoping to get something done this weekend. I want to change the RSB in the R32 first and then tackel the fuel filler neck and the front brakes in the 964.
oh... let me update the list, I got the silver Carrera logos for the sides I will need to fix the side sills trim before putting those graphics on.
#53
Jim, sorry, did not see your post asking where I live... I just sent you a PM...
I will post the process for the replacement of the ceramic resistor...
#54
I added the cat bypass to the list and the stabilizer links... Also posted a photo from Patrick L. rebuild where I found a photo of the valve covers (so you can see the corrosion that is similar to what mine looks like...)
Stabilizer links that need replacement...
#56
Super Duper Moderator
So, are you going to try to chip the old O2 sensor off or just spring for a new one?
Oh yeah, approx. what is the weight saving?
Thanks......Marc
Thanks......Marc
#57
I'm thinking my next project should be figuring out how to get one of you "real" project guys down to NY to help out on my car!
I just don't know how you guys do it.
Firstly, I haven't the knowledge, though this site goes a long way toward solving that problem.
Secondly, I haven't the time. I guess a couple of small children and a "traveling" job don't help.
I do envy you all getting so much work done on your cars. It's not like I need much done, but there are things I'd like to do.
All in good time, I suppose
Cheers,
Dave
Cheers,
Dave
#58
Thanks......Marc
Thanks......Marc
Weight saving aprox 10lbs... here are the numbers:
Old cat - aprox 15lbs
By-pass - aprox 5lbs
#59
Cheers,
Dave
Cheers,
Dave
#60
Same here - any larger project that has been done has put my car off the road for a week or two -- trying to get an hour or so in the evenings or weekends to get things finished....once I have done all the jobs my wife has lined up for me.
One small child (age 2) and a job with long hours means the car jobs, while a great way to relax, are ranked below spending time with the family.
Marc
Marc
