Porsche 964 - 200kg challenge
The following 7 users liked this post by Jonte:
alver (02-17-2022),
John McM (12-12-2021),
kos11-12 (12-12-2021),
No_snivelling (12-13-2021),
PAOLOP (12-16-2021),
and 2 others liked this post.
#258
I know exactly how you feel when you forget to install a part and have to undo everything. sigh
Great vid. Thanks again.
I'm dying to see the episode when you drive this car man.
And the final weight loss total.
#260
Who's rockers are you using? The 964 splash oiling system works fine so long as the squirters are clear and working. They shoot oil towards the oiling holes you point out and have worked for every 911 engine up till the 993. I converted my 993 rockers from hydraulic to mechanical for my track car. Since I started with a 993 engine it was rather cheap to do. The 993 rockers are forged vs the earlier cast iron ones and there is roughly one pound of weight saved there alone. This is more critical if you plan to increase the revs of the engine.
revolve40 (12-15-2021)
#261
#262
#263
Engine almost complete!
It took a bit of time this time. Long story short…I made some blunders and I ended up loosing a lot of time.
With that said I know have an almost finished engine!
Perfect Timing - Adjusting camshaft timing and valve lash
#265
#266
I have so many questions . In a stock 993 with hydraulic style rockers, I know the oil flows into the tappet to pressurize them - it where does it go from there? The reason I ask is because I don’t see an exit path for the oil with the 964 style rockers…and that seems like it might not keep fresh oil on the rocker shafts. I’m. Ot sure how much would escape between the shaft and rocker bushing. Also - without the hydraulic tappet, does there need to be a restrictor added?
#267
Camshaft indeed. The way the oil comes
from the top of the cam tower to the bottom
is by injecting it into a groove in one of the camshaft journals. Then the opposing holes of the camtower will receive the oil and distribute to
the rocker shafts.
Not all camshafts have this.
the rocker shafts.
#269
the rocker shafts.
the rocker shafts.
There are a dozen threads on converting these but nobody has mentioned this before. I would think the splash oil should feed this and the earlier mechanical cam towers I don't believe had this feature. Now you have me thinking. I am nearly done with my build but I don't have any pics of the camshafts and it has been over a year since I closed things up. Looks like I need to investigate this further.
It looks like I can pull the Bridge from the cam tower to the timing chain housing to the far left bottom and I should see if I have this groove with a borescope. Although as I recall the tube along the top of the cam tower (which used to squirt oil on the mechanical rockers in a 964) is what feeds the rockers? My engine is a 96 993 going in my 964 RSR tribute but will be twin turbocharged.
