Antigravity Batteries
They are having a Labor Day sale this weekend. For those who have bought one lately, which one did you go with and how has your experience been so far? I have no affiliations with the company.
I think most folks are happy with them. For those with an expensive high performance car, this is one of the best mods you can do. Shaves like 30lbs of weight.
I just jumped on here after a long day at the track. Interestingly enough i was just talking to the guy that builds our racecar, and he was going on and on about the antgravity battery he is using in his STU car- raving about how much he likes it and how strong it is. I'm leaving out names, but it's a very strong endorsement. So if weight were a concern, I'd give it a try.
I use their battery tracker product on my 964 and like that a lot. No brainer product.
Premium Sponsor
chad@antigravitybatteries.com
Mike Murphy (09-03-2019)
Is there a way to convert a traditional CCA-type battery to AH?
Premium Sponsor
Mike it does not work like that. They are two seperate things.
CCA mean Cold Cranking Amps. That is the current a battery puts out under a formula taking into consideration a load until the battery reaches 9v.
Ah is the Amp Hours of the Battery. That is the Capacity in terms of Amp Hours in a test of its ability to discharge current under a certain load for a period of time.
But forget the technical testing stuff it too long to write about. Cranking Amps are the Power of the Battery and Amp Hours are the Capacity of the battery.
What are you trying to better understand? Whats you application?
Over the last 3 or 4 years i have done a lot of rc’ing with Lipo batteries and if there is one thing you learn, it’s how much respect you must have for these batteries. They are extremely temperamental and it is pretty easy for a small problem to turn into a big one. Do a quick search for “lipo fire” and you’ll soon see what i mean. In Addition, Lipo’s tend to have fairly short total charge cycle lives, somewhere in the 100-200 range. Now, i would not expect car batteries to be fully cycled, but Lipo’s dont like remaining fully charged either, which can significantly shorten their life. Manufacturers all seem to recommend keeping the batteries at a”storage charge” of around 35-40% if you aren't planning to discharge the battery in the next few days to a week. With all of this going on, how are managing both the safety aspect of the batteries as well as their life-expectancy?
thanks
Michael
thanks
Michael
Premium Sponsor
thanks
Michael
thanks
Michael
While I'm sure most have seen some of the flaming battery videos like with the Hooverboard battery fires, that is not remotely what we are doing, nor does it represent Lithium Auto or powersports batteries. It does however show a little bit of mis-information out there for the average Consumer about Lithium. So for us its about education on this type of product. We understand it's new, and with the media generating information about fires from LITHIUM-ION we understand that. But for those who don't know, "Lithium-Ion" just means ANY rechargeable Lithium battery chemistry. But under that umbrella term "LITHIUM-ION" are SEVERAL different types of Lithium-Ion chemical make-ups like a Lithium Polymer such as Lithium Cobalt which is rated at 500-1000 cycles. They operate at different voltages and some are very safe, some are much less safe, but as stated the variant used as Starter Batteries are Lifepo4 and are a safe direct replacement for lead acid while being up to 70% lighter. In addition a few current manufacturers are using them in their performance Cars now such as Porsche, Mercedes, BMW and others.
Premium Sponsor
It’s just that most people who shop batteries are used to seeing the CCA rating and not the Ah rating. My car came with an Interstate that says 730 CCA (910 CA), but I don’t see anything about Ah. So while I agree that these two are different terms, the people buying them might want to equate the two.
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/629x523/ah_e23798ad75bbe900547f28af6b42184a11ee8f63.jpg)
Mike Murphy (09-05-2019)
Premium Sponsor
Scott answering here.... I now understand your original question. Make sense and we might be overlooking something due to being too "close" to our battery and not understanding what the customer is looking at.
Since Lihtium is so powerful we are rarely pointing out the Cranking Amps aspects. With Lithium Batteries the cranking current/power is about twice that of lead/acid. So even our very tiny batteries can start any Porsche. But though lithium is 2x the cranking power of lead, it also has LESS Amp Hours than the same size Lead Acid battery... so since most the performance guys are looking for the lightest option we usually talk mostly in Amp Hours since those directly correlate to how long the car can sit without needing to be on a Charger.
But within all those Amp Hour numbers there is an issue that Lead/Acid batteries have which is called "Self Discharge" , which means that a Lead Acid battery actually discharges while sitting ... so if you take a 40Ah lead battery next to a 40Ah Lithium... though they are both the same Amp Hours the Lithium would retain its voltage much better since it has massively less natural "self discharge" than a Lead/Acid Battery. So with all these factors you can get away with a lower Amp Hour Lithium Battery in a Car and not have to match the number that the Lead/Acid manufacturers quote in their specifications.
Sorry if that make things more confusing... but it is sometime hard to explain while writing this stuff out.
911Jetta (09-06-2019)
Hi Scott, it all makes sense to me. I think it would be a selling point that your batteries can produce more CAs even if it’s not super relevant to the application of track cars and race car.
I used to run my batteries pretty hard when I was into car audio (alternator off) with 20-30amp average draw for several tens of minutes. Now I treat my batteries well. I never leave the lights on or drain the battery. I start the car and drive off immediately, especially when I need to use the heated seats, lights, heater, etc. For my type of use, even the smallest Ah battery you provide would be more than ample and save a large amount of weight.
I also don’t let the car sit. It gets driven often.
Also had a 5 lb. 680CCA Battery Tender for almost two years before this battery.
