964 Forum 1989-1994
Intake madness. Teardown begins....
Old 02-03-2020 | 06:21 PM
  #286
wallra's Avatar
wallra
If you look at the control solenoid you'll see a black plug it just a cap to keep dirt out but it lets vacuum release so the flap can close. I know on my car this operates at 5500 RPM's on the gt3 intake I have now vacuum pulls the flap closed it's spring loaded to open it. I guess they do this so when the engine is low on vacuum the flap stays open.
Old 02-03-2020 | 06:34 PM
  #287
Ubipa's Avatar
Ubipa
Originally Posted by Goughary
That's an interesting point. I hadn't considered that. The valve is not actuated by vacuum however, it opens when the Wide open throttle micro switch is pressed.
The this would raise testing questions...anyone want to venture a guess how to test?
The resonance valve is actuated by vacuum... How you have it setup, with the plug on, the first time the resonance valve is trigged it will be stuck open since the vac can’t be released. If you want to test, apply vac to the line and trigger the vacuum valve.
Old 02-03-2020 | 07:47 PM
  #288
wallra's Avatar
wallra
that plug is a filter. If you look at it you'll see it's open on the sides
Old 02-04-2020 | 03:55 PM
  #289
Goughary's Avatar
Goughary
Ok so out goes the plug and the original - which does not come with the replacement unit, I'll just pop onto the new one...and good to go.
As to how the resonance flap is actuated- yes it's correct that it's actuated by vacuum. However- it's only actuated by vacuum once the wot switch is pressed- which then this little unit switches open- and the vacuum that is used is then coming from the vacuum canister. So in effect, the resonance flap is electronically controlled in that sense.
I'd still like to figure a way to see the rear port in use- so maybe I'll attach a balloon to it after i get everything back together and see what it's doing.
Old 02-04-2020 | 05:26 PM
  #290
RSroadster's Avatar
RSroadster
2nd Gear
Pierburg Vacuum Valve Cap……here is an image of the cap, with the the openings on the back.
Old 02-05-2020 | 12:09 AM
  #291
Goughary's Avatar
Goughary
Found this:
So here is the setup in the car...
Which means that - in our case - with power off, the vacuum is being supplied to the vacuum canister from the intake, and with power on, the vacuum is then traveling through from the intake and the vac canister to the resonance flap.
Then we would have to assume that on power off, the vent on the right hand side of the solenoid in the photo allows the pressure to dissipate and the resonance flap closes by its return spring.
Old 02-05-2020 | 09:21 AM
  #292
Ubipa's Avatar
Ubipa
Found this:
Attachment 1311791
Nice! Your intake is looking too good to be caught up on a small technical speed bump and possibly a loss of low end power.
Fyi.. I remember someone on this thread asking about the seals/bearings for the resonance shaft on the plastic intake. It uses brass bushings and 8x12x3 oil seals.
Old 02-05-2020 | 10:19 AM
  #293
Goughary's Avatar
Goughary
That's interesting- i was going to pull the one apart that i just took off the car and check that out. Do you happen to know a source for those seals and bushings?
Old 02-05-2020 | 10:32 AM
  #294
Ubipa's Avatar
Ubipa
The bushing/bearing is brass flanged sleeve, it would be hard to replace and I don’t think it was meant to (see pic). I’m planning to just add some dry Teflon lubricant. The seal I just grabbed a set of rubber VG oil seals off amazon.
Oil Seal 8X12X3 (2 PCS) Oil Seal Grease Seal VG |EAI Rubber Covered Outer Diameter with Sealing Lip 8mmX12mmX3mm | 0.315"x0.472"x0.118"
Amazon Amazon
kos11-12 (08-10-2022)
Old 02-05-2020 | 11:16 AM
  #295
JasonAndreas's Avatar
JasonAndreas
Technical Guru
I'm lost here? So you are saying that on an early aluminum intake stack, there is a physical connection between the WOT switch and the vacuum line attached to the resonance flap actuator?
Old 02-05-2020 | 10:50 PM
  #296
Goughary's Avatar
Goughary
No Jason...the clicking of the Wot switch sends the electrical signal to the vacuum solenoid that opens the vacuum to the resonance flap...
Sorry if that got confusing. Some of this and the reasons behind it, I'm learning as i go along. It's a strange mixture of vacuum used for performance reasons and also for environmental reasons. So it's good to finally put some documentation down and get the systems sorted. They seem so complicated until as we see now, they really aren't all that complicated in the end.
Old 02-06-2020 | 11:57 AM
  #297
JasonAndreas
Technical Guru
The Service Information Techniks have a pretty decent explanation for how everything works.
In this case, or at least for the plastic intake, the resonance flap is controlled electronically by the ECU and operates completely independent of the WOT switch.
The description is accurate enough that you can map what's written in the documentation to the actual ECU source code;
PHP Code:
REV-LIMITER
@@20:
mov A#0xA
movc A, @A+DPTR
    mov R2
61CB 0x03
    mov A
movc A, @A+DPTR 61CA 0xA3 6520
    add A
R2
    cjne A
RAM_RPM_VALUE, @@21 Turn Fuel off at 6640
@@21:
jc @@TurnFuelOff
    mov A
movc A, @A+DPTR 61C9 0x87 5400
    cjne A
RAM_RPM_VALUE, @@22 Close Resonance flap at 5400RPM
@@22:
jnc @@25
    add A
R2 61CB 0x03
    cjne A
RAM_RPM_VALUE, @@23 Open Resonance Flap at 5520rpm
@@23:
jnc @@27
    mov A
movc A, @A+DPTR 0xA3 -- Turn Injectors On
    cjne A
RAM_RPM_VALUE, @@24
@@24:
cpl C
    jnc
@@27
@@25:
cpl C
@@TurnFuelOff:
mov SOLENOID_RESONANCETRUE if RPM 6640
@@27:
mov P2#0x7E ; '~'
mov R0#0x5A ; 'Z' ; 7E5A
movx A, @R0
    jnb ACC.6
, @@28
    setb SOLENOID_RESONANCE
@@28:
jnb STATUS_STARTING, @@30
@@29:
clr SOLENOID_RESONANCE
@@30:
ret
Old 02-06-2020 | 06:24 PM
  #298
Ubipa's Avatar
Ubipa
Love me some assembly language, but how do you have this and is this accessible somewhere? It so odd to see source code with developer comments for a bosch EFI.
Old 02-06-2020 | 08:52 PM
  #299
Goughary's Avatar
Goughary
So now we need to review what actually happens when the wot switch is pressed. I think we always had the understanding here that it controlled the resonance flap.
I have that service technik somewhere. I'll have to look that up.
Fwiw/ the throttle body in that pic in the service technik you posted is the very early version that has the dual resonance flaps. One on each side. That seems to have been dropped shortly after production began. Perhaps there wasn't enough vacuum to open the flaps on a consistent basis? With two springs the system was a little heavy. I have one of those old units here.
Old 02-06-2020 | 10:05 PM
  #300
Goughary's Avatar
Goughary
So- here is the full diagram of the system from that tech manual up above. I knew i had a copy of that somewhere. Found it buried in old notebooks...
And there is another page further back that describes the adjustment of the throttle off switch and the wot switch...
Quick Reply: Intake madness. Teardown begins....
