964 Forum 1989-1994
Intake madness. Teardown begins....
Old 09-05-2018 | 09:59 AM
  #196
Goughary's Avatar
Goughary
If you do, post your progress here. I'd like to see how it goes and if you have any hiccups and solutions i haven't come up with
Old 09-05-2018 | 08:31 PM
  #197
Goughary's Avatar
Goughary
ISV side note. I was having a problem pressing the parts in far enough. And i found out an important tid bit. Heat the housing prior to installing the steel cylinder- This will allow you to press it in with less pressure- if you do it cold, you will likely bend the housing.
Anyway. Aside from destroying good parts...somehow i wasn't getting the pieces back in by around 2mm. Very strange.
Also now having taken it apart 100 times...when you put it back together, the way to line up the shaft is to set it up so the "door" in the front is closed. Then drop the part, with the spring attached, in, so the spring sits in the correct orientation at rest, with the door closed. This will make sense when you try it.
Then pull the spring and press the gear looking thing down- lightly. Into place.
Install the spring, the spacers, then e clip and the cap. Done.
Old 09-12-2018 | 09:10 PM
  #198
Goughary's Avatar
Goughary
On the ISV...
Here's a tidbit...i took the unit apart again to get the internals to seat properly. And over-pressed it and the center shaft moved slightly off center and that just kinda sucks. So i put it aside and thought maybe to buy another to have another to rebuild, as it would be nice to have a fresh one in the car when all this goes in.
None of this is necessary- as cleaning your isv the old fashioned way clearly works. I'm just having fun making old stuff new again. So don't go crazy thinking you have to take apart your isv.
Anyway. Turns out....you can buy an isv for a bunch of other cars, 944, bmw, Volvo etc...for next to nothing all made by Bosch. Just not the one for our car. For our car, you are screwed. As with everything for a 964. You can buy a used 944 isv for 20 dollars all day long. For us, it's 100 dollars all day long. What gives?
But. Many isv were made for many cars. And guess which one is virtually identical to ours, minus the two pin connector? Our friend the mercedes 190e. They should rename that the Mercedes 964...cuz dammmm.
That isv seems to use the exact same housing. And you can buy them all day long for....20 dollars. Soooooo, i bought one, and will swap my internals to the Mercedes housing and get that thing done and out of the way.
We learn here about the Porsche tax. And the "I'm a heavy handed dum dum" tax.
Onward then to other things. I bought a bunch of hammer handles- i have a few heads for ball peen hammers that i need to have in use...and could have been useful for this job. Various sizes. All extremely old, of course. Cuz if it ain't old i tend to dislike. So, since they are pertinent to the job at hand, if anyone wants to know how to restore a hammer....I'll post the process here. It's kinda fascinating. Gotta love wood.
In other news...I've been spending my 15 min shots doing a little sanding and shaping on the one intake manifold I've been working on. It's coming along slowly but surely. I think I'm ready to throw a coat of primer on the manifold. It's not perfect, but the paint and a little more sanding will inevitably cover some imperfection.
Carrera badge is not mounted, but i was trying to figure out exact placement - here are some pics. The manifold will be two tone - i think black up the legs and silver for the top. We will see.
That's all for now. Leather tools arrived, so at some point I'll be making some leather goods for the car as well. And maybe a watch bandit this guy:
Because apparently a watch needs to match the interior of the car...
Old 09-12-2018 | 10:13 PM
  #199
JasonAndreas's Avatar
JasonAndreas
Technical Guru
How well can you read German? All of the specifications for the different Bosch ISVs are actually documented
Old 09-13-2018 | 08:56 AM
  #200
wallra's Avatar
wallra
use two part epoxy caliper paint self levels fills in all the voids. plus hi temp
Old 09-14-2018 | 06:58 PM
  #201
cjoenck's Avatar
cjoenck
I am a native German speaker so happy to help with translation. Let me know what you need.
Old 09-15-2018 | 06:26 PM
  #202
LimeyBoy's Avatar
LimeyBoy
My wife asked me something and i answered "wait, I'm reading about screw heads" - she rolled her eyes and walked away in wifely disappointment, but likely proud of how incredibly manly it is to even care about a screw type
Wife just asked me what I was reading and I answered "some dude refurbishing an intake manifold." Got the rolled eyes and some comment I ignored. Great thread, great read. Thanks.
Old 09-15-2018 | 06:46 PM
  #203
Goughary's Avatar
Goughary
Best thing about women...is if they didn't roll their eyes, they'd be more like a dude...sooooo thank god for eye rolling...
I did the first coats of paint on the right hand manifold today. More to come once i can tape it off and do the other color...
Old 09-15-2018 | 08:06 PM
  #204
Goughary's Avatar
Goughary
And here are some mid paint pics...
Next up is to tape it off and hit the lower part with a darker paint. I'm going to give flat black a try and see how that looks. Should be nice.
Old 09-15-2018 | 10:04 PM
  #205
Meatball964's Avatar
Meatball964
Love the look of the smooth intake, nice progress!
Old 09-16-2018 | 05:45 PM
  #206
Goughary's Avatar
Goughary
Started on the left side manifold today...
From this:
To this:
To this:
And then gave the top. Quick once over with the sanding wheel. So the big part is done. Now to shape and smooth that out...
Old 09-16-2018 | 09:32 PM
  #207
RicardoD's Avatar
RicardoD
Are there different color Kevlar sleeves?
Old 09-16-2018 | 09:48 PM
  #208
Goughary's Avatar
Goughary
Not sure Ricardo. I just went with the natural color - yellow.
Keep in mind that the Kevlar and the shrink tubing increase the od of the lines- so new clamps will be needed that are larger than stock. For some of them. Most of the normal hose clamps open wider. But the high pressure clamps and oetiker clamps need to be purchased in a larger size.
Old 09-19-2018 | 04:36 PM
  #209
Goughary's Avatar
Goughary
Anyone trying to PM me - i just cleaned out my pm box - - which means I have no previous msgs - so please expect that I have forgotten any previous communication and forgive me...lol
I do everything on reenlist over my phone - I happen to be home today w access to a computer - and on the phone for some reason I couldn't clean those boxes out.
Further - I have gotten "visiter" msgs on rennlist- which I won't see on my phone - So use the PM and not "visiter" messaging pls if you need to get in touch - And for those of you that have me on fb or have my phone....text is always quicker and best.
Thanks - now back to our regularly scheduled program.
Old 09-20-2018 | 02:19 PM
  #210
urquattro20Vt's Avatar
urquattro20Vt
Interesting project - satisfying to clean up years of oily smudge.
Sorry if I missed these answers in prior posts....
Obviously it can only help - we know that even if we'll never know "how much".
There's the obvious question if you will notice any increase in power (or increases sharpness in response) - or more scientifically if you did you dyno the car before the project?
Or did you install a vacuum/boost gauge and see what kind of vacuum you were pulling on decel, or at 3000 rpm or something. Would be interesting to see if there's a difference.
Anyway - good job.
Brandon
'91 964 Turbo
Quick Reply: Intake madness. Teardown begins....
