Ealokens Porshe 951
Old 01-12-2021, 05:53 AM
  #481
Voith
Voith's Avatar
What was the reason for failure?
Old 01-12-2021, 06:04 AM
  #482
ealoken
ealoken's Avatar
8mm shim in cyl 4.
Then the weather came and messed with my steel sleeves..
Old 01-12-2021, 08:11 AM
  #483
Voith
Voith's Avatar
Ouch.. That really sucks.
Few turns of flexhone should bring the cylinders back in no time though.
Old 01-12-2021, 08:12 AM
  #484
ealoken
ealoken's Avatar
Thats the plan
Old 03-06-2021, 12:30 PM
  #485
ealoken
ealoken's Avatar
Round 3
Old 03-16-2021, 12:07 PM
  #486
Noahs944
Noahs944's Avatar
Originally Posted by ealoken
oil pump is ported, hoping it will deliver pressure to 7000rpm.
I understand you are looking to increase oil pressure near red-line (above factory spec) by somehow porting the pump. Would you explain a bit more on this, I'm very interested on the modification and philosophy!
Old 03-16-2021, 12:27 PM
  #487
ealoken
ealoken's Avatar
The idea behind this is to lower the vacum before the pump, making catitation and shiming the oil harder.
Making it easyer for the pump to get the oil in.
Old 03-27-2021, 03:25 PM
  #488
ealoken
ealoken's Avatar
So, the threads holding the oilpickup went ****.
the bottom end is in the Block again.
Old 04-03-2021, 10:16 AM
  #489
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Erik, this blows, can you elaborate on what led to the failure of the threads? Does this engine have BS's installed? Are you using solid or semisolid motor mounts? I am installing modded oil pickup tube and considering further gussets to help prevent any pickup tube related failures this weekend.
Old 04-03-2021, 10:18 AM
  #490
ealoken
ealoken's Avatar
This has been over torqued by someone one time.
Im running OEM mounts.
Old 04-04-2021, 09:33 PM
  #491
URG8RB8
URG8RB8's Avatar
Sorry, that sucks! Thanks for the reply.
Old 04-28-2021, 08:05 AM
  #492
ealoken
ealoken's Avatar
kW v3 sold, hello KW clubsport 😁
Old 04-28-2021, 04:59 PM
  #493
Chapman951
Chapman951's Avatar
LS swap?
Old 04-28-2021, 05:00 PM
  #494
ealoken
ealoken's Avatar
Originally Posted by Chapman951
LS swap?
No way!
The engine is coming together again.
But the big house renovation takes all my time.
Chapman951 (04-28-2021)
Old 05-18-2021, 04:44 PM
  #495
ealoken
ealoken's Avatar
Arp - 100ft
cometic
So, a huge step forward.
Voith (05-19-2021)
Quick Reply: Ealokens Porshe 951
