8V Dyno Mash
Old 08-01-2014, 09:27 PM
  #31
lart951
Basic Sponsor
lart951's Avatar
what about old school 355 with pump gas @21psi huh
Old 08-01-2014, 09:40 PM
  #32
refresh951
refresh951's Avatar
Just for you Luis, very respectable.
Old 08-01-2014, 09:52 PM
  #33
lart951
Basic Sponsor
lart951's Avatar
I can only imagine what it must be when your turbo kicks at 4500rpm.
Old 08-01-2014, 09:59 PM
  #34
refresh951
refresh951's Avatar
A very addictive experience. Heading up to the Tail of the Dragon tomorrow morning.
Old 08-02-2014, 12:07 AM
  #35
George D
George D's Avatar
You are correct sir.
Originally Posted by refresh951
I got the data from the link below. Looks like it is hp:
https://rennlist.com/forums/6877520-post1.html
Old 08-02-2014, 12:39 AM
  #36
blown 944
blown 944's Avatar
Should also do a torque graph too.
I'm thinking I better hit the dyno soon. LOL. Before I get dropped..
Old 08-02-2014, 12:53 AM
  #37
Paulyy
Professional Hoon
Paulyy's Avatar
There are some pretty cool lines!
Vote to keep this going!! To see how many different set ups we can get on here
Old 08-02-2014, 02:52 AM
  #38
TurboTommy
TurboTommy's Avatar
E85 allowing a lot more ignition timing after peak torque. E85 is amazing stuff, I have run 25 psi with up to 35 degrees of ignition timing (at 6K) without any knock counts.
Did you experience power increase all the way to 35 degrees, or was it more of an exercise of how much advance could be tolerated without knock?
Or maybe, power was flat after say 28 degrees?
Old 08-03-2014, 02:11 PM
  #39
Tom M'Guinn
Tom M'Guinn's Avatar
Clearly I need to do something about that top end... When I did that chart I was actually running a lot more timing, but didn't have a knock counter/V-knock at the time, and not surprisingly was changing head gaskets a lot. Since then I've added the knock counter and v-knock and lowered the timing quite a bit to keep the knock count down. Water/meth injection helps to add back some timing, but still not as much as I was running when I did that dyno. I'm plotting a course to give E85 a shot, since a few enviro-friendly alt fuel stations have sprung up fairly close to me over the last year or two... Stay tuned!
One question though -- how can you be sure you're knock counter is actually working if you don't get any counts at all? My first counter went bad a while back. After a day of driving around with a 0 on the counter, I knew something was up. On E85, do you still get a few random counts off boost etc to at least know the counter is working?
Old 08-03-2014, 02:42 PM
  #40
refresh951
refresh951's Avatar
Definitely more power after 28 degrees, it got better all the way to 35 degrees. I did not feel confident going higher and even backed off a bit as I am not monitoring EGT. I am running an ultra stroker however.
Still very impressive power numbers Tom.
I get occasional knock counts when shifting, generally down shifting. If I drove around town for 15 minutes or so with no knock counts I would get suspicious something was wrong.
Old 08-03-2014, 10:35 PM
  #41
George D
George D's Avatar
Hammer Tap?
Old 08-03-2014, 11:04 PM
  #42
eman930
eman930's Avatar
Man maybe one day I can play with the big kids too
Old 08-03-2014, 11:21 PM
  #43
333pg333
333pg333's Avatar
Got a brief email back from my tuner today. He said he tried advancing ign past peak tq and didn't see any worthwhile gains so just dialled it back due to racecar loads on motor. fwiw
Old 08-03-2014, 11:27 PM
  #44
George D
George D's Avatar
Going back to the dyno. Someone has to beat Special Tools remarkable WHP dyno chart..
Old 08-03-2014, 11:32 PM
  #45
refresh951
refresh951's Avatar
I am guessing your cam plays a big role in this.
Quick Reply: 8V Dyno Mash
