VW/Audi 07K (2.5L 20V I5) Swap Thread
#1382
#1384
Speaking of bolts... included in the bellhousing hardware package are longer flywheel bolts. I recommend using these instead of the ones that SPEC sends because of the stack up thickness added by my pilot bearing adapter. I also suggest using some method to prevent these bolts from backing out of the crankshaft holes, whether it is a safety wire (you’ll need to drill the heads), or Loctite blue (not red). I’ll probably just start with some Loctite blue on mine.
#1388
For the one m10 (class 10.9) hex head bolt that fastens the driver side engine mount bracket: 55-60 ft-lb.
For the flywheel bolts I provided, which are m10 x 1.0 (class 12.9), I recommend using the VW factory flywheel bolt torque spec. My guess is around 64 ft-lb.
Note that the stainless steel bolts should not be torqued to the same values as class 10.9 bolts (that would break their heads off). I would basically just snug them up and then maybe an addition 1/8 turn. Optionally, use Loctite blue to prevent them from backing out. I provided SS bolts for cosmetic reasons, in places where the loads are much lower.
#1389
I would not suggest loctite on the flywheel bolts, factory spec is 60Nm (44 lb-ft) +90 degrees for both Jetta 6-bolt and TTRS 8-bolt. Don’t forget to put in the magnetic pickup ring and diamond disc (friction washers) on the TTRS version.
#1390
Thanks for that flywheel torque spec. Why no Loctite? The reason I’m suggesting it is because the 6 bolt interface seems to be a known issue on these engines; flywheel bolts come loose and break (I think).
#1391
The reason high power 07K 6-bolt flywheels come loose is the six bolts and crank-flywheel friction surfaces are having their torque carrying capability exceeded, stretching the bolts out. Loctite won’t prevent stretching the bolts. This is why the TTRS went to 8 bolts plus friction washers.
If the stock six bolts aren’t going to cut it for the turbo guys then I suggest ARP high strength bolts (ECS and IE carry them). ARP includes higher torque spec (which I cannot locate right now of course). Personally I am going with TTRS crank plus ARP bolts, just to be safe (although the forged crank itself is also a reason).
#1392
