VW/Audi 07K (2.5L 20V I5) Swap Thread
#1141
This swap is super intriguing to me, and might win me over from the V8 side of things, but the fact that iAbed is involved is seriously off putting. That guy is by far the worst person/company that I have ever had the displeasure of dealing with, and it's a wonder to me that he's still in business. This thread is a lot to go through, but are there items involved in the swap that are only available from him?
#1142
#1145
Strike 2.
Hi Pot, This is Kettle, How are you doing? I see you have found an avenue where you feel “safe” in posting your banter without repercussion hiding behind an alias "lawn_mower"
No problem , ill bite today Mr.Wobbles
INA Engineering / iABED Industries has never sold Max Wobbles a single part let alone taken an order directly from you.
During your employment at GMP you only handled our orders (which you screwed up twice and Stephen had to resolve).
The only product of ours that you have been in contact with is the parts I supplied for GMP's S3 and the TSI RMS that we supply DAP.
So how does this work?
You handled our orders at your former place of employment , screwed up our orders twice and then left that place of employment breaching whatever customer/vendor privileges I had and suddenly I am the horrible person to deal with? This is juvenile .
Allow me to clarify this publicly. I am not horrible to deal with , you were simply at the other end of my grunt because you didn’t know your job position. 1st order fine you made a mistake , 2nd time? Not so fine almost like you were doing it on purpose.
I apologize if I was rough or rude with you but for a 24 year old you need to understand that the rectification was a complete waste of profit (understand this part) which as an employee (not a business owner) might be hard for you to grasp.
77 pages later with 0 drama and you finally have to add your input like it was needed (as though your rant on ClubMK5 wasn't enough).
If you don't like the products we make then simply put a V8 in your Porsche or better yet , go design your own parts , start your own business and compete but for now no one asked for your opinion and it certainly isn't welcome here.
Do not bother responding as anything further I will action as Libel.
Have a great life.
@Rennlist community. Sorry about this.
Have a great life.
#1146
I'm assuming iAbed is making the adaptor for the original TTRS/RS3 engine (codes CEP, CZG) not the new aluminum block engine? I haven't lookup up parts for the new engines yet, but the only difference in the original 2.5T engine was whether or not an exhaust temp sensor was used. Same turbo for TTRS/RS3 otherwise.
Craig
Craig
the adapter works on both the 8J (MK2 TTRS/RS3 - CEPA|CEPB|CZGB) and 8S (MK3 TTRS/RS3 - DAZA) . The EGT probe as far as I know was on the European 8J models. I have not seen an 8S with an EGT probe. Regardless you can always put one in the downpipe.
If Alan wants to , I would strongly recommend making brackets to convert to a DBW pedal using a MK4/MK5 Jetta / Golf pedal as a good base.
DBW throttle bodies are available in 60mm all the way to 82mm from Bosch and 90mm+ from VDO/Siemens.
#1147
BTW, what kind of fuel economy would the 07K engine (with about 300 HP) get in a Porsche 944?
I understand that fuel economy is not the reason for making such swap, but otoh since the fuel economy of a 951 is appallingly bad for a car of such low drag coefficient and frontal area, and since VW and Audi cars with 07K engines are much more fuel efficient despite higher drag, I'm wondering if the engine swap might not only make more torque and power, but also boost economy.
This car should be getting 40+ mpg at normal highway cruise speed.
#1148
#1149
My daughter had a Passat with the 1.8Turbo and got close to 40 mpg cruising down I-5 from Seattle to SLO, and the Passat drag coefficient is surely not as good as a Porsche 951, nor is its frontal area as small.
Our cars are pretty slippery, and with 5 speed manual transmission should be getting somewhere near 40 mpg at highway cruise speed.
#1150
Rainman
951 looks slippery but is an ancient oxcart fuel economy wise.
you might be surprised at looking at Cd of 951 versus modern VW, frontal area aside.
big bores, "side plug/wedge" 2v head, fixed cam timing, low compression, no EGR....can't put your cruising spark advance and AFR where it would need to be for MPG.
fat tires, short gearing (~3000rpm or so at 75, right?), still a big dead (drag) area behind the tail lights (though improved over a 2.0 924 due to the spoiler).
might as well be comparing these two
#1151
Speaking of short gearing, how compatible will the 07k be with the turbo transaxle in that regard? I have an LS3 996 and that probably the greatest issue with that swap.
Further to do the mileage discussion, the 996 is probably decently aerodynamic, but my tendency to put my foot in it means I never seem to get above 12 mpg....
#1152
#1153
Rainman
Different car entirely but still close enough, my wife's '06 Impreza has a 2.5L 4-valve making about 170hp/tq with gearing that turns 3000 at 75 or so...exactly like an 07K on a 951 box.
It's fine, if a little noisy.
That car with VVT/EGR will average 25 mpg mixed and can touch 30 on a highway trip.
#1154
Another thing to consider too, is the stock engine management system for the Volkswagen engine is configured for stoichiometric combustion (complete total burn of fuel) per EPA standards. I'm no engine tuning guru, but I know most aftermarket systems allow for any range of custom air fuel ratios, depending on your power/efficiency goals.
So however PE tunes Alan's engine will dictate how efficient the car will be. I would consistently average low 20's MPG with the 30 year old 4 cylinder, so I'd think with EGR, VVT, an oil-air separator (catch can) and other efficiency systems hooked up (which I do plan on doing), as long as you have a rather conservative driving style, you could get any range of Mpg you want. 40 Mpg might be stretching it though.
#1155
To nitpick further, like most modern engines, the 07K doesn't have a dedicated EGR system---rather it uses the variable camshaft timing system to create overlap during certain light load conditions and cause an EGR effect. No EGR hardware necessary. To those planning on running standalone engine management with the 07K, tuning the VVT system and/or electronic throttle body will add to the learning curve, but it should be doable.
