VW/Audi 07K (2.5L 20V I5) Swap Thread
Old 03-22-2020 | 05:30 PM
  #1921
JWebber's Avatar
JWebber
At least the 914 is getting some love right now 😏 .
Old 03-24-2020 | 11:46 AM
  #1922
V2Rocket's Avatar
V2Rocket
Rainman
If anybody would be interested I have a set of 6 of these injectors taken from a 24k mile 997T for $210 shipped OBO
PM me as I don't check this thread often.
Originally Posted by vt951
Just a heads up, be careful which EV14 injectors you pick. Bosch 0280158123 is made for Porsche M97 engine (porsche pn: 99760513201) and uses a dual cone spray pattern.. I think they would need to be clocked differently than the 07K rail tabs allow to properly line up the spray pattern with the intake ports.
I don't know which EV14's the Audi guys are upgrading to... maybe a totally different one. But these seem to be the most readily available and are a nice flow rate for a turbo 07K (~60 lb/hr)
Old 03-24-2020 | 12:05 PM
  #1923
hinton's Avatar
hinton
Originally Posted by V2Rocket
If anybody would be interested I have a set of 6 of these injectors taken from a 24k mile 997T for $210 shipped.
FYI, with the I.E. Fuel Rail you can clock the injectors any direction allowing the spray pattern on these injectors to work as intended.
V2Rocket (03-24-2020)
Old 03-25-2020 | 02:33 PM
  #1924
Cjar's Avatar
Cjar
Have you confirmed if these injectors clocked straight with the IE fuel rail will fit onto your cast manifold?
Old 03-25-2020 | 04:37 PM
  #1925
hinton's Avatar
hinton
Not these specifically but we can confirm on Alan’s as dimensionally his are the same.
Old 03-25-2020 | 04:56 PM
  #1926
hinton's Avatar
hinton
The connectors hit the runners, but mostly clear the other way. You would have to grind down a boss or two on the head, or just clock them a few degrees off.
Old 03-26-2020 | 01:49 AM
  #1927
Cjar's Avatar
Cjar
Awesome, appreciate you checking.
Old 03-26-2020 | 10:10 AM
  #1928
V2Rocket's Avatar
V2Rocket
Rainman
Clocking won't matter as long as the harness reaches.
I should clarify that the injectors I posted about are original 997 Turbo and match the PN provided before, but have an EV14/Jetronic plug, different from the ones in that photo.
Old 03-26-2020 | 03:38 PM
  #1929
Cjar's Avatar
Cjar
M97 injectors (0280158123) are twin-spray, so for those clocking may make a difference, I want to have the spray in the ports as designed. For the original VW injectors or the popular Bosch 980cc/min injectors (0280158040) clocking won't matter, as those are cone spray.
Old 04-01-2020 | 11:48 PM
  #1930
hinton's Avatar
hinton
Default Black Sumps, Round 2!
Hey guys! 3 things:
1: I hope you are staying safe, and sane, during these unprecedented times.
2: Alan and I have been working to get the oil pans shipped and it looks like that will happen next week (see below pic of the pickup tube assemblies)!
3: We ended up with 8 Sumps that are black, and 9 that are zinc (to cover the 17 open orders). We currently have 7 people who would like black, is anyone else interested in using the black ceramic coated sump?
1. Adam Z.
2. Spencer S.
3. Brian S.
4. Alex K.
5. Craig J.
6. Damien K.
7. Joey W.
8.
Old 04-02-2020 | 09:56 AM
  #1931
senior_squishy's Avatar
senior_squishy
Yes!!! Finally something to do during the quarantine! 🤣
okay but in all seriousness, Mike, Alan, please be safe when dropping those puppies off.
Old 04-02-2020 | 10:12 AM
  #1932
JWebber's Avatar
JWebber
By all means ,,,, anybody that wants one of the black ones ,,, claim it . I am planning on powder coating my lower . Also , glad to see you guys are doing well during the lockdown .
Old 04-02-2020 | 10:54 AM
  #1933
hinton's Avatar
hinton
Per our offline discussion we are sending you black.
JWebber (04-02-2020)
Old 04-02-2020 | 01:55 PM
  #1934
hinton's Avatar
hinton
Default MORE GOOD NEWS!
The rear coolant flanges just arrived and will be shipping out next week. That means those of you that have ordered your oil pan and rear coolant flange will be able to permanently install your engines!!!
The following 3 users liked this post by hinton:
dmnted (04-02-2020), JWebber (04-04-2020), senior_squishy (04-02-2020)
Old 04-02-2020 | 02:05 PM
  #1935
senior_squishy
Quick Reply: VW/Audi 07K (2.5L 20V I5) Swap Thread
