Just another 968 turbo...
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
It is too tight to get the 4" intake piping to come out 'normal' style. I am using a 90 degree bend in front of the turbo and routing the 4" rigid piping down and then to the front. There is room in the nose for an air box to enclose the filter. I am looking to reduce the turbo suction noise a little. I would like to get more engine noise under load instead of the normal Hover on steroids sound of an unmuffled turbo intake!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I have used this type set up to make 600hp at 1 bar before - at some point I may play around with some custom cams - but this should be fine for street use!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Also need to so the suspension - Ledas and big reds along with some other goodies.
It will be a little while before the rest of the car looks as good as the engine - I have until spring to get it done!
Here is a shot of the 'test' instrument panel - the added part is the display from a eboost2 boost controller.
Looks great Chris, congratulations.
ps...What c/r on the pistons?
Wow, absolutely gorgeous!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I am not a fan of Polished parts, but that is just is me. I do not want to take away from the build Chris. Great job looks professional. keep posting more pics and video.....
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
My favorite way of debunking the 'must have belt covers' myth is to point out that the PS and Alt/AC belts do not have covers and are located much closer to where any road debris might be a factor - and those belts do not suffer from a massive amount of failures from debris!
Uncovered belts are much better for belt cooling, observation of any deterioration of the belts and my favorite - fixing any leaks. With no belt covers I can fix a balance shaft seal leak in an hour (or less), with belt covers it takes 5 times as much time - as long as you correctly guess where the leak is coming from because you can't see it until the rear belt cover is removed!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
polished aluminum just takes a minute with the aluminum polish to bring it back to new.
I remember that several years ago there were a bunch of listers that were powder coating their blocks...made me cringe then and I wonder how they look now!!
