High performance clutches
Did Novak say he have experience with modifying the 220 mm S2 PP for high power? My S2 Spec Stage 4 clutch holds up to ~570 hp which I'm currently running. Anymore than that and it slips.
Uhm.. He didn't tell me! But i got a response from Clutchnet; their PP should be able to hold 720NM, those are custome PP's.. Than with a feramic disk it should hold the power!
I'm sceptical... their stage 4 clutch with the reworked PP and 6 puck disc is specified to 370 ft lbs for the S2. Sounds like you got the numbers for the 240 mm 951 clutch?
http://clutchnet.com/index.php?page=...art&Itemid=140
No, obviously it would be experimental. However, I have seen some seriously loaded small diameter pp'd in the DSM world, so I'm pretty sure it can be done. Your leg on the other hand.......
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Well you know I went through many different setups trying to get my car to hold. This has been the only one to work for me. I'm sure you're aware of how much abuse repeated launches and power shifts entail.
I wouldn't do anything else now.
I do know that Dave would work with you to get what you need. Even as busy as he's been with all the new stuff in the works.
I've had great success with the Spec clutches with the 951 diameter flywheel and like the quick release. But I really don't want to be a ginuea pig for a modified clutch to hold with the smaller diameter S2 flywheel. That's why I'll probably do a twin disc setup.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
But the thing is that I didn't just throw a set of Mitsu rods in the engine. Offset stroking is not new by itself and I chose Carrillo 1000 hp proven rods and had the crank nitrided for maximum reliability. I'm open to new ideas but with with parts or vendors I trust.
http://www.sinter.si/made-by-sinter
This company repacks clutch friction material with carbon ceramic composite. It will hold more power and will not get burned if abused, but steel surfaces must be flat, since it does not seat as easy as organic friction material.
Looks like this:
![](http://freeweb.t-2.net/gorazdo/subaru/IMG_1377.jpg)
Looks like this:
![](http://freeweb.t-2.net/gorazdo/subaru/IMG_1380.jpg)
Basic Sponsor
We will soon have a new 185mm twin disc kit for the 951 to offer up. Will hold 800 Ft. Lbs. Quicker revs. Quicker shifts.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
So now we have the right clutchdisks.. But how about the PP's? Because according to Clutchnet theirs will hold the 720Nm for the S2 PP..
Hopefully Mike will have a good PP available for the S2 flywheel!
I have a lightly used Spec setup from a 550rwhp 16 valve 3.2 turbo. This uses the 968 bell housing and tt setup for quick swaps. Let me know if you are interested.
1 Post
FYI twin disc set up last maybe 10 k miles at best on the street, lots of launches and very aggressive driving and you will be rebuilding it after 5k miles...speaking from experience
They work great but be prepared to re line the discs frequently in a daily driver or street car and we all know R&R the clutch is a time consuming procedure for the 951.
I hadn't realized that David from Spec is a 951 guy, but he is. He is taking a V8 powered wide body to SEMA. You might try to give him a call or shoot him an e-mail, since he obviously knows both teh cars and clutches.
