My porsche 944 S2 16 valve turbo project
#256
Cerbera clutch I would guess? Interesting... I have to look into this.
No clearance issue at all after grinding/apdating the bellhousing then?
I have always wanted a Cerb, well before I got into 944s, would be fun to adapt this clutch setup on my car.
Edit : just seen the Tuscan mention. Is it the same clutch for both 3.6 and 4.0 engines?
Cheers Tim
#257
#259
Tim
#260
Well I've finally got a smile on my face. We have been out in the car this evening doing a little in car mapping. Checking fuelling etc. and building a boost map. Running it at 1.5 bar dropping of to 1.35 were it catches the soft boost limiter at 7250rpm. Dam it feels quick. Intercooler works prefect and water temp is also very good. It does get a little heat soak when standing in traffic, temps up to 50 degrees but that soon drops when moving. I am well pleased, well worth the wait.
Cheers Tim
Cheers Tim
#267
Would like to see video of car at speed preferably. From inside and out. ;-)
#268
I think about 19psi and 7000-ish on the first 16v motor with pump fuel.
