Refresh951's Hybrid Ultra Stroker Build
#421
My radiator was leaking pretty bad after sitting for ~5 months. This forum told me to let it go or a while as it might seal up again and sure enough after a week or so it stopped leaking. Not sure I trust it in the long run though...
#422
Coming along very nicely
That is exactly what happen to me .... My radiator looked mint ... but the seals must have dried out ....
I was lucky enough to get a Griffin on the Group buy and it is great..
The best part was being able to put a petcock in the drain area ...
#423
Yes, I think it will be.
Yes, I heard this also. I plan on checking it again tonight.
#424
Anxiously awaiting the video of the first start up
#425
Shawn, that looks factory fresh. Fantastic. Bummer about the radiator. One more day till it gets there. Lot of people in the queue to check this build out. :-)
#426
#432
Yeah, it's starting to chill down a bit here too. Only 85f...brrrrrr.....
#433
Freezing cold Wish I was in your climate. best of luck fixing. Looking forward to your startup
#434
Well, after 3 nights of testing my harness and a lot of help from Rogue, I found my harness issue that resulted in my no start condition. I was so sure I had messed something up with the harness but in the end it was just an open wire that had nothing really to do with my refurb. I replaced all the sensor connectors and tested all of them for connectivity but did not do connectivity testing on the firewall connector (up by brake master cylinder). Pin 35 (DME power) was open. I could not find any damage but somewhere it was open. Ran a new wire and she fired right up.
I really want to thank Rogue for his help. He spent a lot of time helping me and his service was above and beyond.
Few things to sort out but overall everything looks good.
http://www.youtube.com/watch?v=R-d58...ature=youtu.be
