Refresh951's Hybrid Ultra Stroker Build
#319
Completed my refurb wire harness. This is a LOT of work. Huge under-taking but really happy with the final product (hope I did not make any mistakes ). I found so many lurking potential problems with my old harness. I think in the long run the time spent will avoid a lot of issues down the road. I also like that all my mod stuff will just plug into the harness.
[/CENTER]
[/CENTER]
#322
Thanks Patrick.
Thanks Eddie. It certainly is not a quick project. My wife is happy to get the dining room table back.
Thanks!
TDR? A time-domain reflectometer? If so then no . I did a lot of basic connectivity testing using an ohm meter.
Thanks!
#324
#327
#328
Hit a snag. My 3" down pipe was hitting the brake master cylinder shield and it was pretty snug against it. I looked at it as I was bolting in the motor and it looked like it was going to clear but last night I noticed it was hitting.
I lowered the motor a bit and pulled out the shield but it is hitting in the one place there is no room behind the shield, right at the corner of the master cylinder. So I am re-doing the down pipe I think it is a bit tighter with this setup because the ATP adapter raises the turbo a bit higher.
I think trying to layout the down pipe with the motor OUT is very difficult to say the least. I am almost done with the new down pipe but it is a time consuming process.
