Official V8 Registry.
#31
Agreed!
X-post this in the 924/944/968 section, probably get even more people.. because obviously some probably have conversions and don't come to the turbo sections for obvious reasons..
BTW nice thread, it'll give me something to brows through.
Also - should put the engine type next to their name and a short list of mods for example
paulyy - ls1, ls2 head, Comp Cam 293LR, long tube headers, Maf-less tune, 400 rwhp
like the 3L reg.
like the 3L reg.
#35
Here's mine...
'89 Turbo had it inspected by a Porsche shop, proclaimed it in great shape. It arrived and it was a total basket case.
'02 Camaro SS LS1 motor
FAST 92 intake manifold and throttle body
EPS 226/230 cam
Kooks 1 7/8" long tube headers
Dual 2.5" exhaust
044 Fuel pump and larger injectors
QuickTime bell housing
Spec Stage 2 clutch and aluminum lightweight flywheel
Mocal Oil cooler
Ford Hydroboost
Big Red front brakes, Turbo S rear brakes, Tilton rear proportioning valve
Bilstein Escort Cup coilovers, torsion bar delete
TPC uprights, oil pan, fuel filter kit, VSS kit, oil filter relo kit
![](http://i20.photobucket.com/albums/b233/docwyte/Nicepic.jpg)
EPS 226/230 cam
Dual 2.5" exhaust
Mocal Oil cooler
Ford Hydroboost
![](http://i20.photobucket.com/albums/b233/docwyte/948badge.jpg)
#37
I have a 948... Actually in the process of a complete suspension overhaul. All Racers Edge and Elephant racing solid bushings. Also doing the 996 GT3 caliper upgrade. Then hopefully at some point adding ABS with the boxter pump. And going with an electric PS fluid pump from a mini...
Since the LS2 was hydrolocked in a flash flood I am also having the motor rebuilt with all forged internals and boring it out to a 402. Spending the money on a new complete fast 102 manifolf, throttle body, rails etc. --- Ron Davis Radiator, oil cooler and all lines will be steel braided with quality AN fittings etc.
Then do a serious cage, some aero etc. My wife is gonna hate me!
#38
'88 Porsche 944 V8 race car
Motons w/Eibach springs
Kokeln F&R adjustable sway bars, shifter, trans mount, rear suspension carrier.
Racers Edge A arms, sphericals, shock mounts, camber plates, spindles.
Tilton bias adjuster and dual master cylinders - custom remote mount
Custom headers
Fabcar exhaust
Spec clutch
951 trans w/Porsche Motorsport S2 R&P, GT Diff, custom cooler setup with pump.
Recaro Halo seat
Aim Dash & Smarty Cam
Delphi MEFI 4B programable engine management system
14" rotors w/big black brakes
Custom wiring harnes
Custom strut brace
Custom splitter system w/ GoodAero rear wing
Square 285/30/18 tire setup
Shield plexiglass front window
Plexiglass rear window
Motorola hard wired radio
KRC power steering pump
Saiku Michi can
OZ Allegerita wheels
and much much more....
Custom headers
Fabcar exhaust
Spec clutch
Recaro Halo seat
Custom strut brace
Saiku Michi can
#40
944S with LS1 mated to a turbo S tranny. Detuned to 300 rwhp to make hp/wt class.
https://vimeo.com/54385848
#42
Here are some pictures of my 944 with a 2002 LS6, I done the conversion myself two years ago. The PCM runs EFILive and I have done all the tuning myself.
Mods;
- Coilovers all round
- 968 6-speed transmission
- 2002 LS6 with 806 heads, soon to have rebuilt 243 heads
- 226/229 575/585 Cam
- Centerforce PP with Dodge 11" clutch disk
- MSD coils
- Modified 968 rear spoiler (made it adjustable)
- Rear Weltmeister adjustable with front Turbo sway bars
- Turbo brakes
The car is very fast, scares me every time I drive it. The cam has a power band from around 3000 to 6500 rpm, pulls hard all the way to the rev limiter (6800rpm).
Mods;
- MSD coils
- Turbo brakes
#43
Rennlist Junkie Forever
Mods;
- MSD coils
- Turbo brakes
Mods;
- MSD coils
- Turbo brakes
TonyG
#44
Thanks for that information, $600 is not bad for that kind of power.
