Patrick's build thread. (IT RUNS!)
#901
Curious to see what kind of results you get with this.
Liquid-to-air intercoolers seem to be popular among the drag crowd, but on an engine undergoing prolonged full load runs, I'm curious if thermal inertia may be detrimental to cooling, especially when it's about oil. In fact I do not think I have heard before about air-to-oil intercoolers.
BMW are using liquid-to-air IC on their current M5 and M3/M4, and I guess they work well enough considerng how small they look, but oil gets of course a lot warmer than compressed air.
What kind of oil temp do you currently see with the 964/993 oil cooler? Isn't it actually a bit too big when used with a dry sump?
#902
The benefits will be mulitple (provided it works!) but mainly drag reduction by removing it from the airstream and also allowing a diffuser to rise up where the oil cooler currently sits.
#903
Interesting... Now that the restrictions on my engine are properly-balanced again (short of going wild on an expensive CAD head work) perhaps I should focus on some of these proper modern neat parts.
So do you plan to move back the main rad in order to make some room for the coolant rad for this new liquid-to-oil IC?
#904
When Patrick mentioned this idea some time ago I did some research and it's a route I want to go too. My coolant temp never exceds 82 deg C so I'm sure it has enough capacity left to cool the coil too.
#905
In that case I don't see how it's going to perform better than an external oil cooler. This is going to keep coolant at a higher average temp, and this is pretty much the reason why people running cars that come with coolant-to-oil engines usually add an external oil cooler. Perhaps installing a massively larger main rad may help?
#906
These Laminova coolers are very efficient and the bigger version should be able to keep oil temps just a little higher than coolant.
Not a bad idea as I almost have the opposite issue. Even with an oil thermostat it takes forever to get my 13 liters of oil up to temp. (Part because oil thermostats always leak through to the cooler)
#907
I see... so basically reducing the area of air penetrating the front of the body may also increase the pressure through the inlet(s) left, thus improving main rad efficiency? I suppose that would depend on the variation of section in the ducting between the inlet itself and the surface of the rad.
#908
#910
#912
As long as the radiator have the capacity to remove the heat added from the oil heat exchanger it's a win/win. I would expect me and Patrick having about the same cooling capacity and I can see that I have headroom in my water cooling system given the temp is hovering around the thermostat values. My coolant temp could even go up 15 deg C from where it sits today before having to do cooling laps so this setup should work well.
#913
Pretty much spot on what Gustaf is saying. Something that doesn't get taken into account very much at all in this forum is the formula which is essentially;
Downforce vs drag vs cooling. To that I add the 4th constant which the engineers overlook....budget.
So essentially the formula is purpose driven. For a T.A. car drag and downforce are paramount. Cooling isn't quite as essential as normal racecars. Of course it's a balance. Yes, only the oil is going to be cooled by water. The Rad and I/c are still air cooled. We are raising the Rad a little purely to make way for the diffusers in the splitter (which haven't been built yet). Step by step. Today's bill was enough for me at the moment!
#914
Just had to post this pic. After a lot of work over the last few weeks it's always a bit of a thrill to see the car loaded up on the trailer ready to go to the track.
Note that the new wider splitter only just allows us to fit. Considering that the trailer was pretty much made for this car by my builder, we didn't take into account that we'd be wider than we were in October last year.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#915
How much extra does the new sway bar setup including mounts and weld in plates weigh compared to the (somewhat flimsy) stock setup? Seems heavy and complex. I count 8 heim's, two radial bearings and a substantial amount of steel plate. I assume mounting plates are 1/4" or maybe 3/16" hot rolled given the substantial forces seen with the high sway bar rate.
