Just ordered M-Tune!
#61
Small Business Partner
#62
Ok, to answer some questions...
By measuring actual airflow, actual manifold pressure, and our 3-dimension maps, the M-Tune is quite good at adapting to different setups. Is it absolutely perfect, no. That said, we expect the AFR to be 95-97% on target, and ignition timing to be much better than previous 2-D and pseudo 3-D setups.
This is where the piggyback comes in. For those wanting to tweak the M-Tune to their exact setup, the PB is very capable. Not only does it allow full AFR adjustment, but it also has timing adjustment table as well.
#63
#65
Drive-by provocation guy
#71
#73
18psi on 91 without any knocking, impressive!
Nice figures, I'm hoping on something similar later this summer (not on M-tune though).
/Dea
/Dea
#74
That's a very nice curve over all with a k26/8. I imagine that's the limiting factor for your car now. I can't wait to see someone's dyno chart with an upgraded turbo, running the M-tune. It'd be nice if it were me...
