Green Hunter dyno - 514 rwhp @ 17 psi
Old 10-08-2010, 01:00 PM
  #91
Paulyy
Professional Hoon
Paulyy's Avatar
Originally Posted by Duke
There was no other cars dynoed at the same time. It's the latest model Dynojet, 424.
Now with my first dyno at Dynojet it's better to dyno at the same place next time to get comparable results s so not much use for me to dyno at Rototest. But maybe Corleone could join in, that would be great. But he has a new, faster toy now...
im pretty sure you would give his GTR a good run for its money, plus arnt they limited to xxx speed? plus with our cars you dont have to worry about what buttons your going to push before a race, ABS..dont have it, traction control..dont have it, suspension setting...none
Old 10-08-2010, 01:09 PM
  #92
Thom
Thom's Avatar
When I refered to Corleone's car it was naturally his 951.
The idea is to compare engines of the same capacity, with a CR higher than 8, running the same turbo, on E85, with similar peak boost, the only major differing part I can spot between the two being the head, 8V against 16V.
Old 10-08-2010, 01:19 PM
  #93
Duke
Duke's Avatar
Haha.. seriously though, my car is no match for his tuned GTR.
Old 10-08-2010, 01:36 PM
  #94
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by Thom
Very nice curves, congrats!
No knock at 17psi on pump gas with a high CR just shows the 16V head is safer than the 8V head.
I always thought the same thing. Seems like common sence, but after ST was doing the high hp on his 2.5, he was dead against going 16v.
Knock is usually traced back, assuming proper tune, to excessive back pressure. So if you have twice the valves, you get twice the flow?
Maybe a 20v head would be the best for us. 2 intake and 3 exhaust. ???
Old 10-08-2010, 05:31 PM
  #95
Tom M'Guinn
Tom M'Guinn's Avatar
Do you get any shudder/chatter when starting off? Any signs of slippage under power?
Old 10-08-2010, 06:01 PM
  #96
Duke
Duke's Avatar
Yes, the 6-puck disc usually shatter during take off. No signs of slippage at all.
It's spec'ed to 500 ft/lbs which I'm below so it should be fine. For now
Old 10-08-2010, 10:32 PM
  #97
TurboTommy
TurboTommy's Avatar
Not exactly the same turbo.
I think they have different turbine wheels; Corleone's is smaller.
Old 10-09-2010, 12:54 AM
  #98
Paulyy
Professional Hoon
Paulyy's Avatar
i think his is larger with a 1.02 a/r
Old 10-09-2010, 05:26 AM
  #99
Duke
Duke's Avatar
Yep, we have the exact same turbo except for my smaller (0.82) turbine housing.
I'm changing turbine housing this winter to a Tial SS but will stick with the current a/r.
Old 10-09-2010, 05:30 AM
  #100
Paulyy
Professional Hoon
Paulyy's Avatar
with the TiAL hotside make any spool or top end difference?
Old 10-09-2010, 02:15 PM
  #101
TurboTommy
TurboTommy's Avatar
In one of his posts he mentioned that his exducer size was 62mm. Isn't yours 68mm; if you have the full, as is gt35xxx?
I'm just talking wheel size, here; nevermind about the housing.
Old 10-09-2010, 06:43 PM
  #102
Duke
Duke's Avatar
Shouldn't make any difference at all. It's a bit smoother on the inside so if anything it should gain top end but that's probably negligible.
The pro's is smaller physical and has a nice v-band input.
Old 10-09-2010, 06:45 PM
  #103
Duke
Duke's Avatar
My is 68mm. Corleone bought his turbo through me so it should be the same (unless he changed it which I cannot remember hearing anything of).
Old 10-09-2010, 06:49 PM
  #104
Duke
Duke's Avatar
Another thing, this should be the highest rwhp dynoed for a 944/968 engine on pump gas?
I've never seen a chart or heard about a higher chart for pump gas...
Old 10-09-2010, 07:22 PM
  #105
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
Didn't tool do more on pump ?
Quick Reply: Green Hunter dyno - 514 rwhp @ 17 psi
