Hmmm, build progress...
Old 06-05-2010, 09:04 AM
  #106
fast951
fast951's Avatar
Originally Posted by docwyte
YES!!! Passed smog today with the Vitesse stage 2 kit, 83 lb injectors and LR 3" cat on the car!!! I'm so freaking excited about this, you can't even imagine!!!
Just need to set the boost maps and the car will be done!
Congrats.
It sounds that you solved all the vacuum leaks and you have no wiring/ground issues. The engine management is functioning as it's supposed to, even with the 83# injectors.. Glad the shop didn't revert back to stock parts for the test.
Make sure the 3bar FPR is in place and not the 2.5bar.
Enjoy!
John
Email
www.vitesseracing.com
Old 06-05-2010, 12:30 PM
  #107
gregeast
gregeast's Avatar
Whooooot!!!!!!!!!!!
Can't wait to see it.
Old 06-05-2010, 11:28 PM
  #108
docwyte
docwyte's Avatar
I confirmed the car has a 3 bar FPR. I'll have a brand new 3 bar FPR for sale shortly...
Old 06-05-2010, 11:34 PM
  #109
gregeast
gregeast's Avatar
Is it parked in your garage now? Impressions?
Old 06-06-2010, 09:31 PM
  #110
docwyte
docwyte's Avatar
Haven't brought it home yet. Need to have the wiring to the left rear turn signal repaired, boost maps set and a few odds and ends done. Should bring it home early this week.
Old 06-08-2010, 01:07 AM
  #111
docwyte
docwyte's Avatar
Got my smog test results tonite.
HC 1.3272 Max allowed 2.000
CO 2.8631 Max allowed 20.000
NOx 2.4003 Max allowed 4.000
So passed easily. This was with some E85 in the tank, FQS in position 2, so -5% fuel, Vitesse's "smog" map and the LR 3" cat.
Old 06-08-2010, 01:12 AM
  #112
gregeast
gregeast's Avatar
The good news is that w/o the smog testing you might not have found all the stuff that needed addressing, or at least not while the shop still had the car.
Old 06-08-2010, 01:27 AM
  #113
docwyte
docwyte's Avatar
Yep. Turns out a bunch of engine ground connections were loose as well, so not making good grounds. Car now is running well, need to track down the wiring break for the left rear turn signal and set the boost maps.
Old 06-08-2010, 12:20 PM
  #114
docwyte
docwyte's Avatar
One step closer, got plates for the car today! Can't wait to actually drive this car...
Old 06-08-2010, 07:07 PM
  #115
PorscheDude1
On the Radar
PorscheDude1's Avatar
Awesome! Congrats to the end of a long journey.
Quick Reply: Hmmm, build progress...
