CPRacing: V3 Splitter/PICS....
#271
I have not seen anything from others, but my V3 did not survive its first outing, but it was ENTIRLY MY Fault. I knew I should have bought more than one. Fortunately, it can be fixed. BTW, my rods arrived as I was leaving for the track. Thanks Patrick.
#272
As in collision/off roading, or was it due to downforce?
#273
Nader,
What I happened?
FYI....I ran the unit last weekend in the best "simulated" race environment I could. averaged 135-145 for 2 mile stretches then dipped through some curvy roads (70-85) and back to 135-145.
Did about 8 of these runs and did not have any issue with scraping, bottom out, etc.....and the backroads are definitely worse than a track. I did have all four supports firmly bolted up.
Feedback please. Want to make sure I am getting this right for everyone.
What I happened?
#274
Nader,
What I happened?
What I happened?
#275
OT.. I love the way my V1 looks bolted to my curb decoration... but my radiator and hoses should be here this week..WOO HOO
#276
Two were included in the cost of the unit.
I used four...well...because I had four
All indications, it solved the problem. No issues to speak of. When I was experimenting with support lengths I used four (2 long, 2 medium) just to see how they would line up...and just left them on.
My recommendation is to use 2 rods upto 135mph sustained, and 4 rods for +135 sustained. These units will create a tremendous amount of downforce, obviously the greater the speeds the greater the downforce. Provisions for supplemental supports need to be incorporated into ones thought process when deciding upon the real world application the unit will see.
To help out, I will be more than happy to offer additional supports to any original purchaser AT MY COST ($55 + shipping). As I stated before, I want to help everyone get the desired result they seek, PERIOD. Profit is not my goal. Your satisfaction in this product is.
Let me know if I can help in ANY way.
Thanks,
PATRICK
#277
My take is that there is definite deflection at speed especially if you only use 2 supports. How much deflection and how much this affects performance, I don't know? If you are running on the track and you don't ride huge kerbs or go off the track, then I can't see any issue with these. I still wonder if having steel cable instead of rigid supports mightn't be a bad option so that it allows the splitter to flex upwards if you have a clearance issue, but limits the downward movement at speed?
#279
Nader,
What I happened?
What I happened?
I am sorry to not have responded sooner, but I was away. I had a mechanical due to a burst coolant hose and tried to pull into a service road to keep the track green. I think that there was a low place that caught the side as I drove off track. As I tried to state in my post, this had nothing to do with the quality/design of the splitter and was totally my fault.
BTW, when you call the FG supplier, they always ask how many of the item you want which to me has always meant that these pieces are consumable. I am very happy wiith the product
Best
#280
Finally got my splitter installed today.
It's been sitting around a while, but now it's on! I probably have 6-8 hours into the install, over the course of several days.
I had to make brackets for the rear sides - I bent some pieces of steel, welded on a bolt, then pop-riveted it onto the splitter. Came out very nice.
Then, instead of turn buckles, I used marine cabling to support the front lip. For a clean install, I did all crimp connections (after making a tool for my shop press). The cable and all hardware is stainless (and some copper crimp ends).
I had to take the bumper cover off to attache the center 2 brackets - that was the bulk of the time.
Anyhow, the next nice day I have time, I'll take it out for a drive with my data acquisition, and we'll see if it makes measurable downforce.
Pics:
![](http://www.ephotomotion.com/944/IMG_2064_resize.jpg)
![](http://www.ephotomotion.com/944/IMG_2067_resize.jpg)
![](http://www.ephotomotion.com/944/IMG_2073_resize.jpg)
![](http://www.ephotomotion.com/944/IMG_2077_resize.jpg)
Pics:
![](http://www.ephotomotion.com/944/IMG_2075_resize.jpg)
#282
Nice going Van. That's the way to do it with 4 cables. This will allow some upward deflection yet only go a certain amount downwards during deflection. I ripped mine almost in half when I forgot that the stays weren't on there and it got deflected down and caught the road. Crunch time. Ouch. Guess I'll try the V1 that's in the shop.
ps be careful where you drive with your's on. They're very low and are prone to scraping or catching on stuff.
#284
Your car doesn't look very low in the pics but I can't tell if it's on the hoist in all of them. The extra ride height will help some.
