My norwegian track car
#136
I spaced it out after your post and the differnce is so much,,, alot more angle and i always got this little bit extra steering when i'm on the edge of spinning
i put 6mm on each side
Spec out 7:45 in this video
http://turbocrew.is/videogallery/video8.php
happy to hear you got more angle.. it does sooo much, its a must in a drifting car! this winter I will find a way to get even more angle, hopefully a lot more! I have to make some mods to the little arm on the spindle, that goes out to tie rod end.. if I shorten this by around 20mm, I think I will get better steering response and angle. I will MAX out the angle that possible, with the steering system I have now. the more angle, the better!
do you have any toughts about getting more steering angle?
and are you gonna build a new car this winter? do you know any spec yet?
