My norwegian track car
My track car
hi
My car is soon getting ready. I am real exited how its gonna work. I have not started the car yet, after the engine rebuild. So a few more days, I hope it will wake to life.
anyway, here are some pictures.
as said this is going to be used in drifting. I'm sick and tired of all the skyline, supra, 200 sx(240 sx) that rules the drifting tracks. So I tought it would be fun to kick some rice ***!! and use a diffrent car, and try build it a little serious. not like the imported crap they drive a round here.
I have the cage custom buildt by some of the best here in norway. it really gets the car more stiff, witch is a must!
here is a spec list of the car.
engine
-custom JE 100.5mm pistons, Piston Coating / Ceramic Dome & Skirt for alusil,Fly Cut, Heavy Duty Tapered Piston Pins, JE piston rings
-Pauter rods
-new bearings and gaskets
-Cometic head gasket
-SPEC alu flywheel
-SPEC stage 3 clutch
-balanced crank inc flywheel and pullers, and weight adjusted piston and rods.
-LR maf, mafterburner piggyback
-super 65 turbo
-3" downpipe, 3" exhaust
-Tial wastegate
-Tial dump valve
-front mount IC, 3.5" thick
-Setrab 25 row oil cooler
-big alu radiator
-4 liter oil catch can
-deleted balance shafts
-72ibs injectors
-custom oil feed from engine to turbo
supension
Bilstein escort cup coilovers, 850ibs at front, 600ibs at rear. deleted torsion bars. alu/delrin bushing front and rear, LR camber plates, weltmeister strut brace, solid engine and trans mount
brakes
Big Black brakes, 993tt disks, Tilton floor mount pedals, 3 of 75 series Tilton master cylinders, remote kit, AN 3 teflon steel braid lines all the way, D2 handbrake, Tilton Brake Proportioning Valves, Tilton Floor Mount Throttle Linkage Systems, Tilton Replacement Brake Bias Adjusters.
Inside
Zeitronix zt-2 with every option, greddy profec b spec 2 boost controller,
battery moved in back inside a box. a lot of carbon, summit heater.
a few more pics
the car on its way home after it has got a nice cage
from the engine build
after balancing
engine
-Pauter rods
-SPEC alu flywheel
-super 65 turbo
-Tial wastegate
-Tial dump valve
-big alu radiator
-72ibs injectors
supension
brakes
Inside
a few more pics
after balancing
