BAM!.....602 RWHP 951
Old 11-23-2007, 05:37 AM
  #106
Duke
Duke's Avatar
Good work!!
Now get back there and turn it a couple of 1000's of rpms more
Old 11-23-2007, 06:16 AM
  #107
nick_968
nick_968's Avatar
Hey Tool nice work, been following your progress closely its good to see some out of the box thinking take things to a new level for 951's. What kind of numbers do you expect from regular fuel....if that is an option?
Old 11-23-2007, 07:22 AM
  #108
Geneqco
Geneqco's Avatar
Congratulations Special Tool - awesome work!
Old 11-23-2007, 07:49 AM
  #109
special tool
special tool's Avatar
Thanks again guys.
Wayne - I thought I misread that, but it seems like you got the same meaning.
Old 11-23-2007, 09:32 AM
  #110
944CS
944CS's Avatar
Originally Posted by A.Wayne
Raise the CR to help suppress Detonation, LOL
Congrats Tool, now go get yourself a proper Boost controller
That's not what I said. The only thing you should be LOLing is that dyno sheet from 0-5000rpm
Old 11-23-2007, 09:39 AM
  #111
944CS
944CS's Avatar
Originally Posted by special tool
Well, you don't see the whole powerband because I dropped the throttle at 6,600 in that run - probably would have hit 625 or maybe more but I chickened out. After all - this engine has about 7 hours on it - high pressure is a good way to seat rings.
My goal was ALWAYS to see what I could within the confines of at least some set of rules. It might not be as fast a twin turbo ZO6, but where are you going to race a twin turbo Vette??....NOWHERE.
My engine is legal in MANY sanctions. 100% legal.
As for the street, its pretty much like a 944 around town - kinda nice.
Then if you give 100% throttle and keep it in the power between shifts....well Its pretty quik.
Finally - its important to remember that Tim did my intake for higher revs 8-8500 (like I asked him to) because this is where the engine will eventually be.
Obviously this slows down the air at lower revs also.
It makes more sense now to know that you do plan on running such rpm's, I would like to see that dyno run
Old 11-23-2007, 11:00 AM
  #112
Chris Prack
Chris Prack's Avatar
Just Glyco standard rods and mains.
The clearances were checked by no less than 5 GOOD mechanics......... and me.
The top ring is what Dave/Ski gave me and I gapped to what they said.
It is NOT a normal top ring, however. I don't know the composition, they will probably tell you.
The ring land on the slipperskirt is VERY beefy.
I am going to Disney World.
Be cafeful trying to run that motor over 7.5k with those stock bearings. You need to consider a different style of bearing or it will fail. BTDT.
BTW, I am at Disney World! Seriously!!
Old 11-23-2007, 12:28 PM
  #113
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
I thought this was your comment
Originally Posted by 944CS View Post
Why have you not raised the compression even higher for more area under the curve? You won't have to run as much boost, and thus you'll have a greater temperature differential when the air enters the plenum, which will give you the power you want and also help suppress detonation.
Increasing static CR will reduce his power output at high boost levels and increase the engine's sensitivity to detonation.
Old 11-23-2007, 01:15 PM
  #114
porshaowner
porshaowner's Avatar
Originally Posted by Rock
Have you seen this dudes videos? He shifts at like 9000RPMS
don't question 944cs .he is onto something . i asked him once where he shifted he said the light was set at 9370 but he tries to shift before that something about 9410 being a problem area ,balence shaft belt vibration.by the way there is a video of a guy at pocono in a 951 with a lot of mods getting passed like he is standing still. listen to cs's car when it goes past the 951 looks like 100 more horsepower and sounds like no other 944 i've ever heard.
Old 11-23-2007, 01:40 PM
  #115
333pg333
333pg333's Avatar
Where?
Old 11-23-2007, 02:15 PM
  #116
Fishey
Fishey's Avatar
I am sorry hope you get home soon...
-Your Pal
Fishey
Old 11-23-2007, 02:20 PM
  #117
944CS
944CS's Avatar
"You won't have to run as much boost pressure"
Old 11-23-2007, 10:42 PM
  #118
DFASTEST951
DFASTEST951's Avatar
That is really something Jim. Congratulations!
Old 11-23-2007, 11:11 PM
  #119
m42racer
m42racer's Avatar
Well done. Now buy some parts made to keep that baby together.
Its becoming very apparant, the cream is rising to the top. It's taken longer than I thought, but it is happening before our eyes. Custom Engineered Products is becoming the company that is offering the parts and services the 944 world have all been waiting for. They are showing us that quality and design win over low cost every time. I had a brief conversation the other day and was brought up to date what's coming down the pipeline. The future looks good for those that want really well engineered products. It's no surprise that some of the better known vendors are now buying their products and offering them in their product line.
We need more to do the same.
Again, well done and thanks for sharing.
Old 11-24-2007, 12:58 AM
  #120
ehall
ehall's Avatar
Congrats ST. Well done. It's been great watching you keep the faith and remain focussed on your goal.
Quick Reply: BAM!.....602 RWHP 951
