Corleones new engine is running
Old 10-08-2007, 07:41 PM
  #121
333pg333
333pg333's Avatar
That's the beauty of ems.
Old 10-09-2007, 12:39 AM
  #122
Guns951
Guns951's Avatar
What size tires and what brand (compound) are you running front and rear, and how's traction holding up with all that power?
I'm mystifyed a narrowbody is handling that much power!
Old 10-09-2007, 01:45 AM
  #123
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
What have you done to the head to make it more knock resistant?
Rogue
Old 10-09-2007, 04:42 AM
  #124
Corleone
Corleone's Avatar
265/35-18 and 285/30-18. Kumho R-tyres, Ecsta 70 I think.
I have a pretty flat torque curve so I dont have to much traction problem yet, not with 1 bar of boost.
Old 10-09-2007, 04:46 AM
  #125
Corleone
Corleone's Avatar
Rogue
Squich area is a bit modified. Also the pistontop that meets the head. I also use beryllium seats at exhaust valve to help get rid of the heat. The exhaust valve is sodium cooled 42 mm.
Old 10-09-2007, 05:39 AM
  #126
gt37vgt
gt37vgt's Avatar
I asked a while ago 16v or 8v everyone said 16v then all i see are 8v well I'll go 16v as i'm sure it will be cheaper than an 8v in the end without factoring the head cost just head prep.
and I'll ask this again maybe some keen tuners reading what head is more knock resistant??
looking at factory comp ratios it should be the 16v but here in turbo land it not proven.
Old 10-09-2007, 06:03 AM
  #127
333pg333
333pg333's Avatar
Well you have the cfm's to start with in the 16v, and as you say the standard reply to the knock factor is that the 16v is better, but there is the matter of tq. Depending what you want from your car and where you're going to drive it, may determine what is better for you. 8v or 16v. Again most people say that the 8v is better for tighter circuits for low-mid range out of the corners. I don't know if anyone has done any quantifiable research or even their seat of the pants impressions. Thing is that it is highly unlikely that you would just slap on a 16v head and not change some other things as well as the basic components that have to change anyway so it's hard to do a direct comparison.
Old 10-09-2007, 07:12 AM
  #128
gt37vgt
gt37vgt's Avatar
well i was referring to 400+ hp 3.0 set ups as i said I will just use the 16 because it bolts strait up to the 3.0 bottom end and two will make 500 hp without a port job or cams witch makes it a port and cam job cheaper than a 8v. looking at the powerhus dyno comparison of the 2 you have to make 500hp to make good use of the 16v . meaning a 400hp 8v is faster than a 400hp 16v but a 500hp 16v is easier to build than a 500hp 8v .
i wonder if the cars in that powerhuase comparison had the same turbo not fair if one set up is 3psi infront of the other or 500rpm lower boost threashold rpm
Old 10-09-2007, 08:12 AM
  #129
333pg333
333pg333's Avatar
Well you're probably right on both counts. Still it would be nice to see some real world comparisons. I'm betting on a track in Australia there wouldn't be much difference in the times though. One would have the advantage over the other at different parts of the circuit.
Old 10-09-2007, 08:21 AM
  #130
gt37vgt
gt37vgt's Avatar
well when done it will be fare to compare my car to dukes as i will have a similar turbo and IC I have seen a few good torque figures from 16v lately but not full graphs .
Old 10-09-2007, 09:28 AM
  #131
333pg333
333pg333's Avatar
What's your e.t.a.?
Old 10-09-2007, 09:35 AM
  #132
Corleone
Corleone's Avatar
A 16V head is always more knockresistant and make more power. If you compare a 16V/8V engine built the same way with nice cams, a prepared head and so the 16V will probably make up to 100 hp more. A 16V head with new Ferrea valves, beryllium seats, 2 new cams/springs etc will cost about $5-6000 if it should be done properly. Up to 500 it can be easier with a 16V but you also have to other modifying like intake, exhaust manifold and so.
So... with a 8V you can have at least 600 reliable hp, do you need more? Thats the Q. Isnt a 600 hp 951 enough for most of us to handle? I think that. With more power/torque there will be drivetrain/more traction problems. You also have to build a very stable shortblock if you wont more than 400 hp. For 500 and more you probably need a good sleeved block.
Old 10-09-2007, 09:56 AM
  #133
gt37vgt
gt37vgt's Avatar
at this stage I've never seen any evidence to suggest a fully stock 16v head wont make 500hp with the appropriate bolt ons . i think its really out there to spend 5 or 6 K on a head thats good for 500hp strait up . maybe even more .
Old 10-09-2007, 09:57 AM
  #134
Corleone
Corleone's Avatar
Here is the Rototest graf. See www.rototest.se You have to read it right...!
Red is torque
Blue is rpm
White is hp
This run is 5.88 second, from 3200-7100 rpm
Power is 150 hp at 3200 rpm and 449 (330 kw) at 7000 rpm. No hp loss up to 7600 rpm (another run).
Torque is between 493 nm (at 3200) and 526, average is 505 nm (all this torque with 12% calculated drivetrainloss).
Old 10-09-2007, 09:58 AM
  #135
Duke
Duke's Avatar
nah mate, my current engine installed in the car is a 2.5 l..
Quick Reply: Corleones new engine is running
