Corleones new engine is running
1 Attachment(s)
Finally the new engine is started. It is running fine. Now it will be a lot of tuning with gas and then I will change to E85 (ethanol that you can buy at he gas stations here in Sweden). I have now runned about 20 miles and started to tune. I have not boost more than 0.5 bar but I can say that the power will be there...
I will make some video clips soon... Here is some short spec: 3 liters Darton sleeved JE coated pistons Milledge cam with solid lifter´s and titanium retainers All bearings coated SFR 4-1 exhaust manifold Tial 46 with its own 2½" exhaustall way back Head with Ferrea 48 mm intake valves and 42 mm sodium exhaust valves with beryllium seats 14.5 mm head studs with modified block, torqued with 175 nm Special made intake with shorter runners and "real" velocity stacks, 6 liters volume. 65 mm trottle house 1600 cc injectors Special made IC with flowed test tanks, 4½" x 24" x 16" Garret GTBB Link G2 MSD DIS 4 Race |
Sure is a small turbo...............
Ummm, wow.
Your car is amazing. What kind of hp are you shooting for with that setup? I have a feeling it will be enough haha. |
congrats, looks SWEET! :D
1600 sure beats my tiny 1000cc's I'm also going to run E85. what did you do with cam sensor? is the dump resirk into the intake and the metal piece is support? does that means you are still running MAF? or just don't like the sound? is there a bigger thread on 944sverige? I looked but didn't find any. |
Originally Posted by 5speed300
Ummm, wow.
I was kidding - that whole car is nuts.
Nice job - looks very professional. |
1600 sure beats my tiny 1000cc's I'm also going to run E85. what did you do with cam sensor? is the dump resirk into the intake and the metal piece is support? does that means you are still running MAF? or just don't like the sound? is there a bigger thread on 944sverige? I looked but didn't find any. Yes, the dump is recirculation into the turbo comressor inlet to help maintain turbo rpm. The metal piece is for the hood lock, its just at the picture it looks so. No I dont run maf, I run map. The bov sound is a bit lower but still very high as it sounds thru the very big KN filter, it measure 12 x 6". |
Originally Posted by Corleone
Calcuated power is about 500 hp at 1 bar of boost with E85 and nearly 700 with 1,5 bar. I have set the rev limit to 7600 rpm.
Can you tell me more about the "Special made intake" please.
. . . . . I can't stop looking at those pics. :icon107: |
so when will you be at the nürburgring so you can test it properly? remember a video camera so you can get the looks of the silly bikers up bergwerk.
how high will you rev? have you tested the heat shielding around the brake reservoir and found it sufficient? |
1 Attachment(s)
. . . . . I can't stop looking at those pics. :icon107: Intake runners is about 85 mm "Funnels" is expanding from 44 to 55 mm All symmetrical |
1 Attachment(s)
how high will you rev? have you tested the heat shielding around the brake reservoir and found it sufficient? 7600 rpm at the most. I did have the shielding with my old engine to and it works, I have 2 layer. But when I have more time I think I will do a real metal one. Here is my IC |
6 liters plenum
Intake runners is about 85 mm "Funnels" is expanding from 44 to 55 mm All symmetrical . . . I think the bar has just been raised! |
