Corleones new engine is running
#151
Corleone, I always look forward to your updates. I remember you telling me of those suspected hot spots some time ago. Firstly how does this become apparent? Is it just your temp gauge increasing or is fluid leaking? Do you run an overflow tank/bottle for the expansion tank?
Have you been driving your car many kilometers in the last year?
Can you take some more video of the car and from inside while driving it so we can see and hear the beast in action? Did you ever take some 100-200 kmh times?
Yes, I have an owerflow tank from my 2 expansion tanks and when the cap is opened and the pressure is gone there is more boiling and the temp will rice.
Engine has now runned about 1500 km and almost at wot... everything except this above works fine.
100-200 is at 6.1 seconds, 100-150 at about 2.5. I think it could be even a bit lower...
#153
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You can use air to blow out the heater core - disconnect the hose at the back of the engine and at the heater return to the pump - blow in compressed air and you will get a lot of the coolant out.
#156
I was also having issues with hot spots. We think this was part of the reason we blew a cometic gasket at number four. It only leaked into my coolant and pressurized the system. I'm going to use the Evans coolant. Thanks for the tip Chris.
George
George
#160
#165
