Best oil filter for 951's -- yeah, I know it sounds stupid
Hi all,
So yes, I HAVE done a search, and came up w/ a few discrepancies. Anyway, none of my previous cars have been as particular as this one when it comes to parts. W/ my previous cars, all I worried about when changing the filter was not to use a Fram.
Anyway -- and I realize how stupid this might sound -- is there an 'ideal' brand of oil filter to use?
I'm coming up on my oil change and don't wanna get screwed.
Again, yes, I know this sounds stupid, but I never want to be caught w/ my pants down.
TIA
Collin
TIA
Collin
Hey Man
I try to get a Purolator One, Mobil 1, or Wix if I can...I have about 6 Mahle filters left on the shelf and had problems with the anti-drain back sections on 2 out of 3. They were all bought in the same lot and the check valves seemed to work for only about 2000 miles in Summer. I knew the valve was leaking when I got lifter noise at start-up in the morning. The Purolator doesn't do it at all between oil changes. Just my opinion and nothing more.
Originally Posted by Lanny Curlett
My .02. I went for the L/R billet filter housing and 8 micron elements.
Also, how many changes does the 8 micron element typically last?
How sure are you guys about the 928 not having a drainback valve? I have been using mahle "OC75's" and never noticed any difference in building pressure. Many other people are doing this as well.
Originally Posted by Cory9584
What would happen if you used a filter without a check valve? I thought it was only to make oil changes less messy?
