Reviews on Lindsey Super Turbos
Basic Sponsor
Originally Posted by por951turbo
Thanks for the info Lart. Those are good number on the 61. Did you get the E or B housing?
Lindsey maf with Mafterburner, wideband. Lindsey super T04e 61 polished with 8 housing. Siemens 55 injectors. Lindsey fuel pump.Bosch 3 bar fpr. Stainless fuel lines. SFR stg II headers, SFR 3" downpipe, SFR crossover pipe, SFR testpipe, SFR cat back exhaust, Lindsey dual port wastegate. Greddy profec B boost controller.
Monkeys Removed by Request
Originally Posted by lart951
The Lyndsey produces 349HP @ 15 psi and spools up at 2800rpm
350hp at 15psi and pump fuel!!! with full boost at 2800.
those have to be the best #'s I have ever hered of.
Basic Sponsor
Originally Posted by porshhhh951
lart you SOB I hate you.
:0
:0
Thanks Rick. How bad is the spool up now that you have it tuned? Do you wish that you would have went with the 65 or 61? What boost pressure were you running for that 327hp run?
It's not tuned yet. I've just got the Wolf-3D running sequential injection and am in the process of going sequential ignition / coil-on-plug. Unfortunately my widefire went again in cylinder No.4 yesterday so Dave Lindsey's sending me a Cometic.
It is performing significantly better now with the cam sensor fitted. Proper tuning should start in the next few weeks.
No regrets about the 75 here.
If you want fast spool, go for the 61. If you want to go more extreme, try the 75.
HTH
Rick
Originally Posted by SamGrant951
I have to ask - what are you going to do with your current setup? ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
The good news is that Majestic didn't rebuild it this time. They sent it off to Turbonetics. It got a brand new Turbonetics center section and new seals again. It also comes with a new 6 month waranty from Majestic. It got whatever the new thing is with Turbonetics and they sell this turbo for $1200. I'll be asking $800 for it. Let me know if you are interested.
Originally Posted by eastendr
According to the boost graph HERE 16 PSI on that run.
HTH
Rick
HTH
Rick
for whats it worth, I've got the super 61 turbo on my car and the spool up is very fast
also, my car produces 421.9 bhp which to my knowledge, is still the highest dyno readout of any 944 turbo so far dyno verified in the UK
the car was built by andrew sweetenham of promaxmotorsport.com and tuned by wayne schofield of chipwizards.com
My Super61 holds 21 psi all the way to red line. At 16 psi it made 350rwhp, at 18, 375, at 21, 401 on pump gas. The power peak is deceiving. It's not where the peak happens, bigger turbos are going to peak higher at higher rpm. For me it's about comparing the the lower end of the curve as it is building power before it reaches peak. Besides, with my tires and the cold weather 350 rwhp is too much.
the car was built by andrew sweetenham of promaxmotorsport.com and tuned by wayne schofield of chipwizards.com ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Rick
A 61 will spool up fast - particularly as your is a 2.8 litre ! I believe the dyno figure of 381.2 RWHP was obtained at ABG in early 2004 ...
Rick
Rick
BTW Rick, your web site is just AWESOME. Thanks.
Time to rethink turbo options for the rebuild perhaps.
