Time to present the "GO BIG.."-project! With pics
Old 10-18-2006, 02:36 PM
  #136
RolexNJ
RolexNJ's Avatar
Originally Posted by Duke
Well.. still no word or reply from Skunk. I'm pissed off! Time to call in the long arm of the law.
Ive been waiting for you to bump this thread. You have gotten to be kidding me, its been how long now? And not a single word? Serious?
Old 10-19-2006, 03:11 AM
  #137
Camaro_Muncher
Camaro_Muncher's Avatar
Damn that skunk stinks! Seems like there is a lot of scammers all the sudden.
Old 10-21-2006, 10:03 AM
  #138
Duke
Duke's Avatar
Alright, I will put the Skunk-thing aside in this thread and post some pics of new parts
I just ordered 300+ feet of wiring for a new harness I'm going to build.
The head. Stock valve sizing.
Tial 44 mm v-banded wastegate.
Tial 50 mm BOV. Gotta love v-band.
Racing valvesprings setup to handle 30 psi.
Custom CNC-milled engine mounts. Semi-solid.
Custom CNC-milled caster blocks with delrin inserts.
Painted front brake shields.
Shift **** insert
Custom delrin bushings for front sway bar drop links.
Grouted block.
Old 10-21-2006, 10:37 AM
  #139
MrNasty951
MrNasty951's Avatar
Duke
Looks like there is a lot of fun to be had!! Good luck man!!
Old 10-21-2006, 11:50 AM
  #140
IMB951
IMB951's Avatar
Can you explain what grouting the block does? Is that the same kind of grout that goes inbetween tiles?
Glad to see your project back underway
Old 10-21-2006, 11:59 AM
  #141
kasturbo
kasturbo's Avatar
Does this mean you worked things out with Skunk?
Why did you not go with larger intake valves?
Old 10-22-2006, 03:55 PM
  #142
Duke
Duke's Avatar
Thanks guys!
No I haven't worked out things with Skunk.
Grouting the block is to improve the structural ridigity of the block and minimize cylinder movement at high power levels.
This was my spare head, the one that was going to be very special is with the skunk.
The work on this head is nice but the stock valves are going to rob me of a lot of power.
Old 10-22-2006, 03:59 PM
  #143
IMB951
IMB951's Avatar
Is this a cheaper/ more effective alternative to sleeving the block?
Old 10-22-2006, 04:06 PM
  #144
Duke
Duke's Avatar
No this is just for some added security with stock cylinders.
Old 10-22-2006, 05:28 PM
  #145
RolexNJ
RolexNJ's Avatar
Kool Duke, glad to see you are going forward!
Old 10-23-2006, 12:16 PM
  #146
TRP951
TRP951's Avatar
Will the grouted block affect the cooling any? What about some kind of girdle at the top of the cylinders to add rigity? something like this?http://www.modacar.com/products/Hond...ock+Guard.html ?
Old 10-23-2006, 12:20 PM
  #147
Duke
Duke's Avatar
Yes it reduces the amount of coolant between the cylinders but the 3.0 liter blocks came that way and the very most of the heat is at the top of the cylinders anyway.
A deck plate is a very good idea but the attempts to make one without having to rebore the cylinders didn't work out.
Old 10-23-2006, 12:32 PM
  #148
TRP951
TRP951's Avatar
Do you mean the outside of the cylinders? Not sure what you mean by reboring?
Old 10-30-2006, 12:20 PM
  #149
Duke
Duke's Avatar
The hunter's got new legs
Old 10-30-2006, 12:41 PM
  #150
RolexNJ
RolexNJ's Avatar
Sweet, which are they pal?
Quick Reply: Time to present the "GO BIG.."-project! With pics
