New Link Datalogging Software
Old 03-29-2004, 11:25 AM
  #106
cpt_koolbeenz
cpt_koolbeenz's Avatar
Nice catch Rob...
The location is different for different versions of windows. I believe what I posted is for WinXP.
Old 03-29-2004, 01:47 PM
  #107
Steve Cooper
Steve Cooper's Avatar
I found a source for RS232 to TTL cables but there seem to be two choices- 3.3V or 5V TTL chipsets. It looks like the 5V is the more typical converter, is that the cable I should purchase to connect?
Really looking forward to trying this out! Just have to get my motor back together...
http://www.superdroidrobots.com/rs232.htm
Old 03-29-2004, 02:59 PM
  #108
cpt_koolbeenz
Steve -
You may be able to make those cables work with some modification. But I would suggest getting the SerialLink on Danno's website: http://www.gururacing.net
Look at the price chart.
Old 03-29-2004, 03:40 PM
  #109
Steve Cooper
Originally posted by cpt_koolbeenz
Steve -
Chris,
Thanks, I hadn't checked if Danno had the cables for sale. It would make more sense for the long run to go with USB rather than serial anyway...
Cheers!
Old 03-29-2004, 10:43 PM
  #110
cpt_koolbeenz
Note the current release does not support USB, but will soon.
Old 03-29-2004, 11:26 PM
  #111
p0wp0w
p0wp0w's Avatar
wait CPT,
your program doesn't work with USB??
That may be the solution because I'm using the serialLink with a serial->USB convertor because the laptop doesn't have a serial port...
Old 03-30-2004, 12:15 AM
  #112
cpt_koolbeenz
That would do it! I don't have a USB Link yet. I need to borrow one to enable that functionality. I will get one soon and get up to speed!
Old 03-30-2004, 12:53 AM
  #113
cantresjr
cantresjr's Avatar
got winxp but still no joy. i also don't have serial only usb
Old 04-02-2004, 08:18 PM
  #114
Steve Cooper
I also plan to see if I can capture the tunng module's signals to the PC, allowing me to integrate the power to change settings in the AFMLink without the need of the programming module. But that is a bit more risky than just plain datalogging.
How close are you to enabling data loading from the laptop to the AFM without the tuning module?
Old 04-02-2004, 08:38 PM
  #115
schadenfreude
schadenfreude's Avatar
No, go your dos prompt and type path. You'll notice that windows\system doesn't appear in the list, but windows\system32 does (unless you've changed it). The last OS to have windows\system in the path by default would have been (I think) win95.
Of course you could just dump the OCX in the application directory, it'll be guaranteed to find the file then. You will probably have to run regsvr32 on it again if you move it, though.
Old 04-02-2004, 11:21 PM
  #116
cpt_koolbeenz
Months... I have to get my car back together so I can continue programming. That will take three weeks. After that, I will get the logging part of the program perfect. Then I will begin working on further functionality.
Old 04-02-2004, 11:25 PM
  #117
cpt_koolbeenz
The program directory is most likely where it is going to be when I package it. until then, since everyone has the program in different places on their PC, one location seemed the most straight foreword. But if anyone cannot get the registering to work, put the OCX in the same path as the application.
Old 04-02-2004, 11:35 PM
  #118
schadenfreude
Yeah, that's cool... hey by the way, I can help you out if you like once I get enough money saved up for a MAP kit, I work as a programmer; mainly do C++ stuff though...
Old 04-03-2004, 12:01 AM
  #119
cpt_koolbeenz
Awesome! I'll PM you...
Old 04-20-2004, 04:05 PM
  #120
Karbokane
Karbokane's Avatar
So should I be invetsing in a serial link or a Usb link? Thanks
Quick Reply: New Link Datalogging Software
