New Link Datalogging Software
#61
0 16 20120 0 6 25 0 0 0 0 0 10162 24 108 10
0 0 0 0 1 -2 0 0 0 0 0 0 0 0 0 0 0 10
0 -2+11 +329 +3 +2 +1 0 0 0 0 0 0 0 0 0 10
0 4 3 6 4 7 7 2 0 1 0 0 0 0 0 0 0 10
0 8 7 3 8 0 0 0 0 0 0 0 0 0 0 0 10
-6 0 3 9 0 0 0 0 0 0 0 0 0 0 0 0 10
0 0 +9+7 +1 +3 0 1 0 0 0 0 0 0 0 10
0 0 0 3 1 6 2 2 0 0 0 0 0 0 0 10
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 10
0 0 0 0 0 0 0 0 10
0 0 0 0 0 +1 0 0 0 0 0 10
72 0 0 0 0 0 0 16 12 56 23 49 0 86 6350 39606 11.88
7 25 24 49 0 36 2033 12705 11.88
6 37 24 49 0 36 2033 12705 11.88
6 47 23 49 0 52 3349 20909 11.88
4 41 23 49 0 39 2049 12805 11.88
38 24 49 0 36 2033 12705 11.88
37 23 49 0 36 203 1207 11.88
6 37 23 49 0 36 2033 12705 11.88
38 23 49 0 36 203 1207 11.88
39 24 49 0 37 203 1207 11.88
41 24 49 0 36 219 1307 11.88
39 24 49 0 7 0 10
42 24 51 0 6 3 10
3924 49 0 6 0 10
42 24 50 0 0 4 10
4 49 21 39 0 33 429 0 49 399 0 33AP TPFM VEN 10
248 39 0 33 409 0 49
This is a startup and the car running for maybe ten seconds, after that the data starts flashing and the scroll bar flashes and the program looks like it is having trouble scrolling down. The car runs fine the whole time.
0 0 0 0 0 0 0 0 10
39 24 49 0 7 0 10
42 24 51 0 6 3 10
3924 49 0 6 0 10
42 24 50 0 0 4 10
#63
Mark, you might have a bad cable. Don't use the long cable that comes with the tuning-module. Just the short one for the serial-link and then a longer serial cable if you need distance.
#64
That is just what i copied and pasted out of the program itself. I will post a comlink sample soon. And I am using the cable that came with the Serial Link box. Danno I dont think the cable is bad because the comlink works fine. I will try to find a log file of the new software, I havent been able to get one saved yet.
#66
I got an actual log file to save, usually they would show up blank. Here it is:
3 97 24 0 8 5 3 0 3 2 4 0 5 2 5 0 1 1 3 0 7 M S VEN 390 77 401
7 6593 4049 0 9 5 38 0 7031 3750 0 9 2 9 0 0 0 9 0 2 5 8 0 7926 26 38 0 80645 29 4992 7845 3151 0 1 4 9 0 0 2 5 0 0 82 25 0 20792 40 49 369 2305 809.69
49 MA OXVECU GA1546 42 49 771 4815
585 3613
781 4801
665 4113
870 5414
10 51 45 51 8252 51512 11.96
98 52 27 49 786 4910 12
39 95 24 0 20 71 29 0 201015 58 49 7149 44601 7741.35
822232 40 49 9752 60908 31634.31
772364 25 49 78 36 28 49 8436 52704 11.38
712227 29 49 8436 52704 27403.35
71 RP TP AF GA 23 35 0 712308 28 49 8836 55204 27406.46
71 23 35 0 732343 28 51 8436 52704 28177.04
71 36 20 50 6136 38308 11.38
41 91 24 0 20709 35 49 363 2207 806.5
20 77 24 0 20 79 23 0 0 20 86 24 0 83 23 0 24 86
Here is an example of a comlink file that is saved into the floppy disk by taking the file and doing the "send to 3.5" floppy" option
40 24 50 21 49
844 42 24 51 0 37 24 49
817 39 23 49 0 36 20 33
836 41 24 49 0 36 21 49
823 40 24 49 0 40 20 49
844 39 23 50 0 36 20 33
841 42 24 50 0 40 24 49
821 39 24 50 0 36 20 33
835 42 24 49 0 40 24 49
843 40 24 50 0 36 20 49
812 39 24 49 0 36 20 33
844 41 24 49 0 37 21 49
846 42 24 50 0 37 24 49
810 39 24 49 0 36 20 33
RPM MAP TPS OXY AFM VECU GAIN ZON
853 41 24 51 0 40 21 49
835 39 23 49 0 36 20 33
832 41 24 49 0 36 21 49
824 42 24 50 0 37 24 49
838 39 23 49 0 36 20 33
831 42 24 50 0 37 24 49
818 39 24 50 0 37 20 33
When i try to save this file the normal way i save files, like file-save as- select floppy disk in drop down menu, it gets all jumbled. Then I can somewhat save it by doing word wrap, but this still makes more rows. What does word wrap do? And why does notepad try to condense files when it saves them? It seems like this is the problem...
585 3613
781 4801
665 4113
870 5414
40 24 50 21 49
#67
Wow! Something is seriously wrong! The problem is that on my car it works fine... We need someone else to try the program and see what they get.
I'm not sure what you mean by saving the files. Make sure your font is Courier New and word wrap is off. Word wrap puts a carriage return at the end of a line that is too long to fit on one line. What do you mean by condense files?
#68
If i try to save the "good" comlink file to another place on the computer, notepad messes it up. For example, copy and paste my file with nice and neat rows into notepad, then try to save it. Then open it up. The new file will be all screwed up, just like the files I am getting with your new software. I know nothing about programming, but this seems like a clue to me.
#69
Go to run and type regsvr32.exe /u mscomm32.ocx and press enter.
Download this and save it to C:\windows\system\
Then go to Run and type regsvr32.exe mscomm32.ocx and press enter.
Then try the program again.
MSCOMM32.OCX
MSCOMM32.OCX
#70
<<<For example, copy and paste my file with nice and neat rows into notepad, then try to save it. Then open it up. The new file will be all screwed up, just like the files I am getting with your new software.>>>
You mean copy the example you posted and paste the text into notepad and save it? I did and it opened fine. Maybe try to open the files with something other than notepad?
#72
Edit, i lied. It only gets jumbled when I take the datalogged file, as in the file I copied this out of: 844 42 24 51 0 37 24 49
and try to save it onto another part of the computer. With word wrap on or off. On both my laptop and desktop, both with windows 98.
Danno, have you tried yet?
#73
Yes, if i copy that into notepad, then save it, it opens up all jumbled. With word wrap both on and off. On both my desktop and laptop, both running windows 98. WTF?
Danno have you tried the new software yet?
