Porsche 944 Turbo restomod
Old 04-22-2022, 05:08 PM
  #421
Frank@Work
Frank@Work's Avatar
Pulling the transmission and transaxle to get to the clutch. I’ve never done it this way. I take the engine out. This time I went for the prescribed way to do a clutch job. I’m at the point where the bell housing comes of. So I’m pretty far with the taking stuff apart which was recently ben put together. I WILL NEVER EVER DO IT LIKE THIS AGAIN!!!!
And again I have to find comfort in drinking.
SeaCay (04-22-2022)
Old 04-22-2022, 06:16 PM
  #422
944M3
944M3's Avatar
I struggled deciding which way to get to the main seal as well. I decided to drop the trans after just having pulled the engine and back in. To me it was more straight forward than pulling the engine, which I find more tedious. Neither way is particularly fun though. Now that I have to do it again, still dropping the trans.
Old 04-28-2022, 03:26 AM
  #423
Frank@Work
Frank@Work's Avatar
Originally Posted by Gage
Great progress Frank!
Love the look of the fuel system.
On the previous engine, way back on post 330, the timing belt was noted to be tracking rearward of a normal position. It appears to be in a rearward position on the new engine as well.
In one of the images of post 318 I can see that the tensioner sprocket is not correct for the turbo engine (it is from a 4 valve engine and too wide for the 2 valve belt), I believe this may still be the cause of the tracking issue. Also on that previous engine the balance belt tensioner pulley was tightened in the wrong direction. It should be tightened clockwise which will bring the upper run of the belt down and away from the waterpump pulley.
Very good catch! Thank you.
I have replaced the wrong 16V sprocket with a new 8V sprocket (will post pictures later) and tightened the balance belt the correct way.
Old 04-28-2022, 03:31 AM
  #424
Frank@Work
Frank@Work's Avatar
Almost back at the point where I can start the engine. Took the pressure plate out, placed the t/o bearing (not aware of doing anything different than the previous time). As soon as the transaxle was installed, I tested the clutch and the t/o bearing stayed put. Yesterday I managed to get the transmission back in. Only the exhaust remains to be installed. Tonight, I first will modify the heat/protection shield for the clutch which doesn't fit with the 3" LR exhaust. This weekend I wil start the engine.
The following 2 users liked this post by Frank@Work:
Gage (04-28-2022), PF (04-28-2022)
Old 05-10-2022, 02:55 PM
  #425
Frank@Work
Frank@Work's Avatar
It's picture time!
Disconnecting the transmission from the transaxle:
The problem:
Getting stuff out of the way to gain access:
Putting it back together:
The wrong 16V (wide) tensioning roller compared to the correct (thinner) 8V roller:
Clearance issues with the LR 3" exhaust:
Everything back together:
After starting I noticed another F'up; used the wrong bolt causing a small leak at the water neck:
Correct bolt:
Time to hit the streets!
Rock solid idle, good oil pressure!
Video
Gage (05-11-2022), SeaCay (05-10-2022)
Old 05-10-2022, 03:00 PM
  #426
ealoken
ealoken's Avatar
Congrats on startup.
Old 05-10-2022, 04:24 PM
  #427
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
It's looking fantastic! One minor comment: you might want to safety-wire the bolts for the wastegate adapter plates as I've heard they can loosen.
Old 05-10-2022, 04:38 PM
  #428
Frank@Work
Frank@Work's Avatar
Will do as soon as I have received the safety wire pliers.
Old 05-19-2022, 01:38 PM
  #429
Frank@Work
Frank@Work's Avatar
The 3” LR exhaust is touching the body at the point where the exhaust goes from vertical to horizontal. Replacing the copper gasket between the downpipe and the exhaust might overcome this problem.
Another possible solution might be putting spacers between the crossmember and the body to lower the entire engine by 2 or 3 mm.
Would this be a viable option?
AR_Motorwerkz (05-20-2022)
Old 05-19-2022, 04:46 PM
  #430
PF
PF's Avatar
I use aftermarket racetype enginemounts. They lower the engine about 15mm. Ofcoarse you get more vibration but on a trackcar like mine not an issue. Could be a option as you say. Finnish 9products makes really good ones.
Old 05-19-2022, 08:52 PM
  #431
Mike Goebel
Mike Goebel's Avatar
I always thought it would be a good idea to use oval tubing for the exhaust if going to such a large cross section area.
Mike G.
Old 05-19-2022, 10:44 PM
  #432
Chapman951
Chapman951's Avatar
Congrats
Old 05-20-2022, 07:43 PM
  #433
AR_Motorwerkz
Basic Sponsor
AR_Motorwerkz's Avatar
Wow!! Congrats! Hard work really pays off! Maybe some mods soon?
Old 05-21-2022, 05:18 AM
  #434
Frank@Work
Frank@Work's Avatar
This weekend I will reach the 1000 km mark on the new engine. Time for an oil change!
For the break-in of the engine I started out with a rom limit of 3000 rpm. This morning was the first time I reached 6000 rpm. During break-in I had to adjust the fuel mappings. This engine runs way better than the previous engine. I'm pretty happy with the AFR I get under load. Still one cell to make a tiny bit richer. I'm verry impressed with the performance of the engine. The 3" downpipe increases spoolup a lot. Stil working on getting the boost curve more stable (EBC duty cycle?). While driving the fluctuations you see in the boost log are not noticeable.
Top chart:
White: RPM
Red: Time in seconds
Green: AFR
Yellow: Fuel map load
Bottom chart:
White: Boost solenoid duty
Red: Boost in mBar
Green: Fuel closed loop adjustment
1 bar ((14.5 psi) boost before 3000 rpm):
This part will be adjusted to get it closer to the 12.0:1 AFR.
Chapman951 (05-21-2022)
Old 05-21-2022, 04:03 PM
  #435
Frank@Work
Frank@Work's Avatar
A short clip:
My brother following me in his 2005 corvette C6
H.F.B. (05-21-2022)
Quick Reply: Porsche 944 Turbo restomod
