Porsche 944 Turbo restomod
#211
Second attempt to install the Tial wastegate failed!
Somehow the pipes don't line up. I suspect the piece of pipe that was replaced on the stock wastegate tie in (wastegate outlet) has been welded in under a different angle.
I've ordered another stock tie in pipe to compare and will try again.
#212
#213
Last night I went back to the drawing board with the Tial 38 and an original wastegate, The only way the adapter plates line up with the original wastegate is when I position the plates in a way that normally would not fit. Grinding of 2 mm from the larger adapter plate is required. Later this week I will try to add pictures. Let's hope my third go at installing the Tial will be successful.
#214
Probably not stupid after all!
#215
Yes! The wastegate is in! The problem was the the 2,25" pipe which was welded crooked to the wastegate exit pipe. Ordered another one and used a different approach. I have shortened the wastegate tie-in pipe on the Lindsey Racing 3" exhaust. This way the flattened part of the wastegate exit pipe would not reach the round 2,25" tie-in pipe on the LR exhaust.
Pictures from the installed wastegate will follow.
For now:
![](http://www.bakkums.nl/porsche/images/20200126_105553.jpg)
![](http://www.bakkums.nl/porsche/images/20200126_105542.jpg)
![](http://www.bakkums.nl/porsche/images/20200126_105530.jpg)
![](http://www.bakkums.nl/porsche/images/20200126_105521.jpg)
For now:
#218
Time for an update!
"Found some money" to get going again. Almost there! Next weekend I probably will turn the key (and keep my fingers crossed).
Lots of new parts arrived:
![](http://www.bakkums.nl/porsche/images/20200303_165701.jpg)
![](http://www.bakkums.nl/porsche/images/20200303_175842.jpg)
![](http://www.bakkums.nl/porsche/images/20200303_165717.jpg)
![](http://www.bakkums.nl/porsche/images/20200303_195859.jpg)
![](http://www.bakkums.nl/porsche/images/20200306_095506.jpg)
![](http://www.bakkums.nl/porsche/images/20200305_195906.jpg)
![](http://www.bakkums.nl/porsche/images/20200306_145616.jpg)
Did not waste any time getting it on the Porsche:
![](http://www.bakkums.nl/porsche/images/20200307_164712.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_164700.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_164740.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_164732.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_164825.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_164801.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_183603.jpg)
![](http://www.bakkums.nl/porsche/images/20200307_183600.jpg)
JET951 (03-10-2020)
#219
Your build is absolutely amazing, don't us those magna core leads though they are junk. if they are the carbon leads they run different resistance for each length, the connectors are rubbish. The original Buru stainless leads are the best. Each lead has 3k ohms
Regards
Sean
Regards
Sean
#220
Regards
Sean
Regards
Sean
*edit* This was 6 years ago maybe they have improved quality since.
#221
Just an amazing job.
I have to ask, how are you so skilled to take on such a project? Are you a mechanic or assembly worker? Just curious because this is outstanding work and such attention to details.
#223
I work as a Business Intelligence Developer (programmer). I have always been fascinated with working on cars. Have been tinkering with cars for the past 30 years. Have been reading a lot and watch a lot of YouTube vlogs / DIscovery Channel (car related). My motto's: just take your time and look before you leap!
Samsung Galaxy S9 phone,
#224
Yesterday I have tried to start the engine.
At first the engine turned over, but did not start.
I checked the DME relay and switched the connectors on the reference sensor and the speed sensor. Previously I had checked which connector was for the speed sensor and which was for the reference sensor. Therefore I did not expect the engine to start.
To my surprise the engine did start, but ran like crap. I did not see a tacho signal on my dashboard.
Today
I found out why my engine was running like crap. The camshaft was 180 degrees of. How I managed to get this wrong I don't know. Checked it, double checked it, tripple checked it and somehow at some point I screwed up. Must have been the booze.
Nevertheless, Moving on.
The currently installed camhousing with camshaft is old and would have been replaced as soon as the engine was running. At this point I know the engine will run and therefore I will replace the camshaft housing with another camshaft housing with a brand new camshaft and brand new lifters.
My question:
Is it possible that I will have to switch the speed and reference sensor connectors again? Or can I be sure the sensors are hooked up correctly and the problem with no tacho is somewhere else?
Today
My question:
#225
Today
My question:
Today
My question:
