Porsche 944 Turbo restomod
#151
Be ware! Not all dampening material is still available!!! You might keep that in mind while taking out the interior.
I think it would have taken me at least 15 hours for taking out the interior and the dampening material.
Prepping for primer will take you at least that amount! Especially the dashboard area is a PITA!
#152
If you go for a 3.0L I recommend using the 104mm Block. They have better cylinder reinforcement and windage ports. No need to spend the $ on sleeves when you could spend it on good pistons. Plus you have a choice of better breathing heads.
#153
Almost a year has passed since my latest post. Is the car done? NO! Have I been doing nothing at all to the car? NO!
I have been collecting a lot off engine parts for the engine build. At first I wanted to go for a LS3 conversion, but that's no longer an option.I was going to sleeve my original engine with Darton MID sleeves, but after four (!) suppliers accepting my order (and my money) and then backing out refunding my money, I have put that build on hold.
Another (pretty) complete 944 Turbo engine has been acquired and the engine looks very good! I will be building the engine with the stock pistons, rods and crankshaft. The internals will remain stock, but I probably will add a crankshaft scraper. Aftermarket turbo, fuelrail. exhaustheaders and motormanagment will be installed. And offcoarse every bearing and seal will be replaced. I'm still awaiting the piston rings, but as soon as those have arrived I will post pictures off the engine build.
And yes, I know I'm taking my time!
#155
Things take time, im 2 year in my build.
#156
This thread is awesome and yet so dangerous. I'm about ready to start the 2nd partial restoration on my car and I see a ton of things you replaced that I should add to my list. Thanks for the tips on the sound deadening; I would have stripped it all off in preparation for my new carpets. Perhaps I'll just leave it alone.
I also acquired a low mile shortblock to build a stock motor. The one in the car will be mothballed for a future build and restoration #3.
(I partially restored mine in 2001 in real time on the list, just like you're doing).
Looking forward to seeing yours all done. It's way more in depth than any attempts I've done.
#157
You will be glad you did not do the LS swap. I bought a 944 LS swap supposedly completed. It was a nightmare to get it to run properly for track duty. However my 89 951 was an absolute dream that I had fun with for 18 years. I kind do miss it.
#158
Because we all love pictures:
![](http://www.bakkums.nl/porsche/images/20190811_111336.jpg)
I've bought an extra 944 Turbo engine. The original engine will become a 3.0 liter turbo (in the future). To get the 944 on the road I will rebuild the extra engine.
![](http://www.bakkums.nl/porsche/images/20190417_182445.jpg)
![](http://www.bakkums.nl/porsche/images/20190418_182045.jpg)
![](http://www.bakkums.nl/porsche/images/20190419_150011.jpg)
![](http://www.bakkums.nl/porsche/images/20190419_150016.jpg)
![](http://www.bakkums.nl/porsche/images/20190419_150246.jpg)
![](http://www.bakkums.nl/porsche/images/20190419_150251.jpg)
![](http://www.bakkums.nl/porsche/images/20190721_141540.jpg)
![](http://www.bakkums.nl/porsche/images/20190721_141632.jpg)
![](http://www.bakkums.nl/porsche/images/20190721_141724.jpg)
![](http://www.bakkums.nl/porsche/images/20190721_141808.jpg)
![](http://www.bakkums.nl/porsche/images/20190721_141836.jpg)
![](http://www.bakkums.nl/porsche/images/20190729_213902.jpg)
![](http://www.bakkums.nl/porsche/images/20190804_133216.jpg)
![](http://www.bakkums.nl/porsche/images/20190804_191302.jpg)
#159
Here are some products to consider.
https://www.crank-scrapers.com/Porsche_944.html
https://www.lindseyracing.com/LR/Parts/PANBAF.html
#160
Ouch! The head is toast!
The ceramic liner in the number one and number four exhaust ports are gone:
![](http://www.bakkums.nl/porsche/images/20190812_205626.jpg)
![](http://www.bakkums.nl/porsche/images/20190812_205407.jpg)
@Humboldtgrin: Thank you for bringing the scraper to my attention.
#161
I have checked out several heads (already) and they all have the ceramic problem!
Why would I be replacing my broken head with a head which will eventually brake as well?
I'm considering a NA head for my build.
Any reason why I should not be using a NA head?
#162
NA head is fine, as long as you use the Turbo Ex Valves... all good..
#164
Did you try contacting Gustaf (aka Duke on Rennlist)? He is in Sweden and had his block converted to MiD.
