928 Forum 1978-1995
Sponsored by: 928 Specialists
Red Car FIRE
Old 08-04-2016, 07:40 PM
  #106
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by docmirror
I qualified it by stating it was MY case, it was based on well documented damage and repairs, and that it drove straight and true, even with the salvage damage present. Also said it was salvaged for financial and not safety reasons.
hmmmmm.....
Understood. This car is well documented, salvaged for the same reason I believe and should have no concern about driveability from the fire damage. Maybe this adds some weight to restoring it even with a salvage title. So, I guess the question is would whatever Van nets after the $11K settlement minus the buy back be more or less than the drop in value from a salvage title?
Old 08-04-2016, 08:39 PM
  #107
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
I suppose this is a dumb question, but why would the injector pop out of the rail if it was clipped? Or was it?
Old 08-04-2016, 11:13 PM
  #108
vanster
vanster's Avatar
Andy
Two thoughts
1) It wasn't really clipped
2) The injector cracked when we tapped on it to make it work.
Old 08-04-2016, 11:50 PM
  #109
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
It cant come out of the rail.
the rail is bolted down onto the injector.
A physically broken injector could do this, or a pinched/torn Oring at the rail end could have blown out.
But injectors cant come out.
Old 08-05-2016, 12:01 AM
  #110
vanster
vanster's Avatar
I agree. The more I relive the event I think the injector was cracked. They were coral colored 4 hole and about half the weight of the older single injector
Old 08-05-2016, 12:39 AM
  #111
Speedtoys
Speedtoys's Avatar
I dunno, NO sign of the PS line cracked near the top of the fender?
Thats a LOT of liquid on fire over the side of the fender outside the bay..not sure how a cracked in jector can do that.
Old 08-05-2016, 12:41 AM
  #112
Speedtoys
Speedtoys's Avatar
Andy
Two thoughts
It still cant come out..unstable, but cant come out...could drop some..and leak, but enough to blow the oring?
Old 08-05-2016, 01:10 AM
  #113
jcorenman
jcorenman's Avatar
I am not sure this is true-- that it can't come out of the rail if the clip isn't secure. The rail is bolted down, correct. And the injector is basically trapped between the rail and intake. And the original-style injectors can't move downward much, because their fat bottoms run into the intake.
If I understand correctly, the injectors were the new-style all-plastic units with skinny hips. Skinny enough to allow the injector to drop down into the intake and allow the top o-ring to disengage from the rail (absent a secure clip)? I don't know, but careful inspection should tell the story.
Old 08-05-2016, 01:23 AM
  #114
bureau13
bureau13's Avatar
Didn't someone (handle of Cosmo or something like that?) have an injector come loose and start a fire? Or am I remembering that wrong?
As for the PS fluid burning, I'm guessing that was a secondary ignition after the line or reservoir burst from the heat of the original fire.
Old 08-05-2016, 01:24 AM
  #115
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,230 Likes on 1,258 Posts
This is not the first 928 fire due to a missing, loose, faulty, or improperly installed injector clip. It's very easy to attach the clip without them actually "grabbing" the grooves in the injector.
In fact, when this thread first popped up I received an e-mail from Mike Schmidt (Z):
"He mentioned that they had just replaced the fuel injectors. I know there have been some engine fires because people didn't install those square metal clips that hold the injectors correctly, or at all."
Not trying to beat a dead horse here, but when anything happens the first thing you ask is: "What is the last thing I did". In this case installed an injector and moments before the flame, the smell of raw fuel.
A cracked injector is also possible, but people cannot ignore how important those clips are.
Anyway - I vote fix the car. All things considered that damage isn't bad at all.
Old 08-05-2016, 01:26 AM
  #116
Speedtoys
Speedtoys's Avatar
But..isnt the car off at this point? No more PS fluid pressure to push out over the fender.
Just saying..1/2 the fender is draped in liquid on fire.
Where do you see a fuel fire at/under/around the fuel rail in the engine bay?
I do not. Just heat scorched plastics and rubber...but no ignition.
Old 08-05-2016, 06:31 AM
  #117
Bill Ball
Under the Lift
Bill Ball's Avatar
Read my description of what happened the day before in post 99.
Old 08-05-2016, 06:34 AM
  #118
Bill Ball
Under the Lift
Bill Ball's Avatar
The fluid drained out of the burned hose, draining the reservoir, forming a large pool that burned, setting the tire on fire and burning through the left fender. It didn't need to squirt out under pressure. The other point of concentration of fire was near injector 8. Plus injector 8 was a bit troublesome the day before. Also, I don't think the fuel necessarily ignited around the injector until it pooled in the valley and dripped down under the car. Anyway, it should be easy enough to check the injector if it is still there. Regardless, there definitely was a fuel fire supplemented at some point by power steering fluid. The likeliest source for the fuel was injector 8 as it had been manipulated several times over the day before the fire.
Old 08-05-2016, 06:38 AM
  #119
Bill Ball
Under the Lift
Bill Ball's Avatar
I believe the stock injectors can drop far enough into the head before bottoming out to allow the top to pop out of the rail. Another local owner installed stock injectors without clips and had a terrific fire on start up. The fuel pressure will push unclipped injectors out of the rail. But, yes, Van's 4-hole skinny injector 8 did come out of the rail when the clip popped off the day before as I was trying to remove the electrical connector.
Old 08-05-2016, 06:47 AM
  #120
Bill Ball
Under the Lift
Bill Ball's Avatar
Read my description of what happened with that injector the day before. It was properly clipped but it came unclipped when I torqued on the electrical connector to get it off the injector. It reclipped perfectly well. I've done this dozens and dozens of times on dozens of 928s. I've had the injectors out of my car alone at least a dozen of times. BUT as I mentioned, it was the first time I have ever seen an injector come unclipped from manipulating the connector. So, in retrospect, there may have been an issue with the clip, rail or injector clip slot even though it seemed to clip just fine. Van did manipulate that injector further the next day. It should be examined.
Quick Reply: Red Car FIRE
