This guy claims to have the 79 Scarface 928. Apparently he says the car is in St. Petersburg, Florida and that the car will never be for sale. He said that it is currently white with 16" rims and that his dad got after filming at his porsche repair shop back then. Link is below. Wonder if anybody can change his mind.
"Maybe I can help, this car is owned by my Father and now resides in St. Pete Fl. He purchased after the movie was shot, as he owned a porsche specialty repair shop, doing one off customs rebuild etc. The car was pretty badly beaten up in filming. It is now white with 16 inch rims. The car is a 79. but was given a light facelift by the film makers to appear just a bit more like the current model (when movie was filmed). No the car is not for sale. No the car will never be for sale in my fathers lifetime. The car and 140 +/- other including a 59 coupe with 19k miles and a 56 speedster that hasn't seen the rain since 58 have all been placed in trust to his church."
I have enjoyed the past 8 years of stewardship of my early, S4 but it will be time to pass this car on to someone else to care for and enjoy. I do not intend to fully market the car until the spring but figured I would post in case someone here is interested in a car that, I believe, is a true 928 unicorn.
Guards Red (Factory original paint on body. Mirrors were repainted)
Black leather manual sport seats with cloth "Porsche Script" inserts
5spd manual (option 481)
Sport Seats (options 383 and 387)
Sport Boge Shocks (option 474)
Piston Squirter Block
Flip Up Rear Wing
LSD (option 220)
928Specialists SS X-Pipe & SS 928 Intl RMB
Factory Porsche Cup I wheels w/o RDK
XPEL Front End Protective Film
Known Service Highlights before my Ownership
September 2007 - 46,212 miles
Clean and flow test injectors (WitchHunter)
Replace brake booster
Replace clutch master cylinder and install GTS clutch
Install new alternator
March 2008 - 46,303 miles
Rebuild LH ECU
Service Highlights since Ownership
June 2011 - 48,150 miles
Replace Water Pump and Timing Belt - new Laso Plastic Impeller
June 2012 - 48,979 miles
Replace Fuel Lines with Greg Brown lines
May 2013 - 49,495 miles
Silicone Oil Pan Gasket, Volvo Motor Mounts, Delrin Steering Rack Bushings
Replace AC Compressor and all o-rings, refill with R-12
July 2014 - 49,593 miles
R&R MAS - Injection Labs
Aug 2015 - 50,397 miles
Repack CV Joints, Replace CV Boots
Odometer identified to be non-functional likely due to broken odo gear
January 2016 - 50,397 miles
Odometer gear replaced (North Hollywood Speedometer)
July 2017 - 50,560 miles
Replace Head Gaskets, cam chains, and cam chain guides
Top End Refresh - Cerakote Intake and Valve Covers, replate all CAD hardware (performed by Tru6)
Replace Timing Belt (Porsche factory)
Replace High Pressure PS Hose
Replace Belly Pan
September 2019 - 50,898 mileS
Change all fluids
Re-tension timing belt
Replace Harmonic Balancer w/ Greg Brown ATI unit
Improvement Areas:
Oil Pressure Sender Leak - there is a small leaks coming from the oil pressure sender where it attaches to the pan. The sender unit is new (replaced when the gasket was done) and should just need the locking nut tightened. We would have done it during the last oil change but the filter was installed and oil filled before we realized the issue.
Dash/pod cracks - the dash has some small cracks starting at the vents and the pod has a large crack down the center. The two options for replacement are to buy new parts from Porsche (availability was confirmed earlier this year) or to have them recovered by R Budd. The R. Budd option would have seams whereas the Porsche option would be factory correct. I figured that I would let the next caretaker choose the appropriate option. I will also include a dashboard core with the car.
Original radio, shift lever, steering wheel, air pump, air pump diverter valve, and muffler will also be included as part of the sale.
All service since 2007 has been performed by Dave Chamberland (Worf928). In fact, we know that Dave has been the only mechanic to perform timing belt service on this car. All service records are available for review. I will plan to detail the interior and have professional pictures taken in the spring but can certainly provide additional pictures as the car sits now to anyone interested. Here are a few pictures.
Asking price: $47,500 USD
Please send a PM if interested
Not quite the market that I had hoped for in the spring but figured I would give this post a bump before the car goes into storage. Please feel free to contact me if you have any questions.
Been a while since I had free time to peruse the for sale ads. Anybody else finding themselves more busy somehow being sheltered-in-place?
At any rate here is what looks like a potential nice driver quality 86.5. Great color and no rubbies. Sure it's got a lot of miles but that probably means the mx was kept up, well at least until 6 years ago. At $8500 its worth a further look.
