928 Forum 1978-1995
Sponsored by: 928 Specialists
928 "S"ixpots
Old Feb 12, 2014 | 08:07 PM
  #31
BC's Avatar
BC
70mm
Old Feb 12, 2014 | 08:17 PM
  #32
xschop's Avatar
xschop
Now add 1\2 the diameter of that base circle that the caliper sets on. That is the center of the spindle.
Old Feb 12, 2014 | 08:22 PM
  #33
White Lightnin''s Avatar
White Lightnin'
Veteran: Army
Why is there more material & a radius at the base of the standoffs with the set up at the beginning of the thread... but appears just a 90 degree junction on the set for eBay? That junction would be more fatigue prone, would it not?
Old Feb 12, 2014 | 08:35 PM
  #34
xschop's Avatar
xschop
Thats a ref pic for the centering rings and those were the mockups for the 951/S2 spindles. All the adapters will be base radiuses. At 180mm bolt centers, adapters can be done for the 130mm radial mount spindles for sure. Keep throwing up measurements and I'll draft it out. I doubt I'll machine those out.
Old Feb 12, 2014 | 09:28 PM
  #35
BC's Avatar
BC
I get it now.
Old Feb 12, 2014 | 10:48 PM
  #36
69gaugeman's Avatar
69gaugeman
Originally Posted by James Bailey
Mark had F-40 six piston front brakes, huge rotors on hats....Kibort has GTS rotors with spaced out S-4 calipers...
Thanks. I wasn't sure. Still for 99% standard brakes will suffice. These will be in my back pocket if I ever get good enough to outdo the S4 brakes I got for my 83 racer.
Originally Posted by xschop
The Porsche calipers do not hold a candle to these Integras. They overheat and boil the fluid long before these break a sweat. Thicker pads is one reason but the piston design on the Integras are Therm-lock trademark and of course 6 vs 4 piston.
I have built tons of custom parts and brake kits for these cars over the years and have yet to see one of the adapters fail. Even Wilwood's Integra adapters don't have the amount of material around the bolt holes that I incorporate into these. If you are worried about Porsche-designed longevity, then you need to consider tossing your A390 block as it's just a matter of time before the heat cycles catch up. Same goes for the crap-forged P-calipers that reach their heat cycle limits where they become un-rebuilable from the severe heat gauling of the pistons.
.....Should be getting a report back from Barber on these.
I agree these are much better than the factory system. Just that not everyone needs that. I like what you have done. It looks fine from a strength point of view.
Old Feb 13, 2014 | 09:22 AM
  #37
xschop's Avatar
xschop
It's an honor to accept your approval Gaugeman. Now if I can only get Hackstetter's seal of approval.
Old Feb 13, 2014 | 06:56 PM
  #38
69gaugeman's Avatar
69gaugeman
Not sure if you are serious, but if so, no need to be honoured.
I will say that if the center-line permits, you might want to look at swapping that aluminum bracket to the other side of the spindle. I am not sure if the tie rod becomes an issue then, but the radiated heat from the rotor will certainly soak that adapter and transfer some to the caliper. The further away from the heat source, the better. Might have to use a hex head bolt instead of an hex socket cap screw.
Long time ago in a land far away since I did any thermal dynamic stuff, but the closer I get to the hot coffee with my mouth the more I feel it....lol. small difference in distance will be a large difference in heat transfer.
Old Feb 13, 2014 | 07:07 PM
  #39
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
FWIW, all of the recent discussion about brake bias valves led me to hike out to the garage to look at whatever valve there is on Anderson's car. Turns out there isn't one. F50's on 355 x 32 rotors in front, stock S4 calipers and rotors in back. Pagid blacks.
I guess if you go big enough in front, the backs can't overwhelm you.
Old Feb 14, 2014 | 12:13 AM
  #40
Danny Humphreys's Avatar
Danny Humphreys
Centering rings are made from 4140 steel....no gauling there either...
I'll have sets on ebay later tonight.
Link to auction?
Old Nov 16, 2015 | 11:00 PM
  #41
xschop's Avatar
xschop
I have another set of these adapters if anyone is interested. I updated the base posts with a filet on the last run so they are Nuke proof. Will Also come with a fresh pair of Cayenne rotor centering rings.....$225 shipped US-48 only. I take Paypal and will ship Priority. Thanks, Rob
Old Nov 17, 2015 | 03:34 PM
  #42
RennPartsDirect's Avatar
RennPartsDirect
Former Vendor
Stress concentrations at the corners are killer...
Old Nov 19, 2015 | 04:28 PM
  #43
xschop's Avatar
xschop
These are 3/4" cross-section 7075-t6
Your wheels wheel fall off first lol.
Old Nov 19, 2015 | 07:28 PM
  #44
atb's Avatar
atb
How about fabbing up a set of adapters for these?
Old Nov 19, 2015 | 07:41 PM
  #45
mark kibort's Avatar
mark kibort
Originally Posted by Hacker-Pschorr
I wasn't paying attention and didn't realize these were for the S spindles.
I have everything in boxes to convert my 81 to S4 brakes, I would much rather go this route......
Is this just a big tease or will we be able to purchase these adapters?
I still have a set of adapters i made to make the 81 brakes use 13" cayanne rotors.
thats a good route, as you dont need S4 calipers!
the hub adapter from Xschop is essential! thx! (from scot! )
