1983 928 NEED HELP PLEASE
hi everyone i live in narrows virigina i have a porsche 928 1983 i sold it to a guy who let it sit for almost 5 years i sold it cause i did not have the money at the time to buy a fuel pump all it needed well i bought it back bought the fuel pump and now it fires up and then dies fuel is getting to fuel rails and injectors spark everything tho seems like they jumped where the fuel pump relay is on 19 spot and ran a toggel switch now the battery is shot but i jump it and try to start and like i said will start every time just wont stay running also i think someone has messed with the screw infrom of spiderwell for air to fuel ratio i am in need of so much help ive spent so much and to no avial im running out of money i have abour 400 dollars left if that ill hafta look please can anyone help me oh also seems as when i hit the gas pedel it dies instant wont stay running more than turn key wrooom putt putt putt dead every time
i also have put in new fuel pump new sparkplugs i noticed that there where the Mass air flow module is and goes down into the whole theres no boot there does there hafta be a boot like where the round metel part goes into the other metel hole that sounds stupid not sure if u will know what i mean but where the part goes into not the mass air flow but the whole unit the air box and all that goes down into engine like a circle spot and fits in there is there not some rubber should be around that or just when u tighen down the air box and all its in there and dont need to be super sealed i know air is a big thing with the cars so im ot sure
Team Owner
First my condolences for the loss of your mom.
you will find a new gf,
did you clean out the fuel tank?
did you replace the 3 running relays?
83 starts and dies, US or Euro 83?
Sorry to hear about your mom, gf that leaves at a time like that good riddance.
Take your time on the 928, without huge luck and/or money it will take some time and money before its safe to drive. Wash it, sit in it and enjoy the leather smell, but take your time before trying to drive it. First thing I would attend to are the high pressure rubber fuel lines, then proceed with a general cleanup.
Post your location and see if someone is local that can take you for a ride to cheer up and have a look at your car.
Screw at front of spider is usually idle speed , not mixture. Sounds like its starting on the cold start injector. If the main injectors are not providing enough fuel, the temp sensor telling the ecu how much fuel to send may have failed, or it maybe the thermotime switch has failed - this provides rich mixture for a short time on start up. Do some research on how to identify the relevant temp sensor (one is for gauge, one is for ECU), check its resistance (3k ohms cold, 2-300 hot) - if it looks wrong, try starting with the connector removed. if it stays running , it will gradually go rich as it warms and die after some minutes - normal for a disconnected temp sensor - replace it.
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
A used, neglected 928 is rarely a source of happiness in the short term.
Just want to share a glimpse of realism with you in order to head off a potential big disappointment.
Good luck.
Electron Wrangler
What Randy said first...?
Always fix what you know to be needed first... So get a new battery - start there, if the battery is fried you may be wasting your time with everything else.
Alan
Alan
Welcome aboard micahatar.
Here are a bunch of links about L-jet cars with problems. Some reading may help you in your work and also help you in your search for resources/info.
https://rennlist.com/forums/928-foru...t-on-cold.html
1983 Porsche 928s - Bad start on cold
https://rennlist.com/forums/928-foru...-jetronic.html
Asking for help..no start 1982 L-Jetronic
https://rennlist.com/forums/928-foru...-no-start.html
Phooey! No start
https://rennlist.com/forums/928-foru...ont-start.html
83 928S Won't Start - 2002-2009
https://rennlist.com/forums/928-foru...-question.html
Another No Start Question
Start 8/10 still going 5/12
Recently purchased 1984 928s auto. Will not start, I drained the tank replaced the fuel pump, cleaned the grounds and checked relays. It has fuel pressure at the rail and 12v at the injectors, my issue i have 12v at the 10 and 29 pins with ignition off but drops to .17v with key on. I have good ground continuity at 5,16,17and 35 pins. Will start with fuel poured in flapper. Any suggestions?
https://rennlist.com/forums/9525668-post2.html
No-start is a common thread here and elsewhere: I know as I'm having problems with my own '82. And so I offer these threads while you wait for responses.
http://forums.pelicanparts.com/porsc...ump-short.html
https://rennlist.com/forums/928-foru...non-start.html
Porsche 928 Non Start
https://rennlist.com/forums/928-foru...rebuilder.html
L jet AFM rebuilder
https://rennlist.com/forums/928-foru...ork-video.html
wanna see an Aux Air Valve at work? (video)
https://rennlist.com/forums/928-foru...em-lemons.html
84 US L jet idle-running problem (lemons)???
83 928 stalled and no start
https://rennlist.com/forums/928-foru...r-pin-out.html
L-Jetronic Connector Pin-out
https://rennlist.com/forums/928-foru...s-in-need.html
84 auto L-jet brain...anyone have one? norcal lemons in need
WALLY'S ANNUAL ELECTRICAL PM thread
Wally's annual PM is reprinted at this link:
"From a link in the newbie faqs....Wally's yearly electrical PM should be in EVERY shark owners files...."
https://rennlist.com/forums/4283785-post5.html
Groundpoints
http://members.rennlist.com/fabric/groundpoints2.jpg
https://www.928gt.com/default5.htm
http://www.928intl.com/repair.htm
https://rennlist.com/forums/928-foru...ting-done.html
Car Won't start. Plenty of searching ans troubleshooting done
Phooey! No start
L jet AFM rebuilder
Groundpoints
