928 Forum 1978-1995
Sponsored by: 928 Specialists
I might just cry (belt tensioner warning)
Old 12-31-2012, 03:49 AM
  #166
Imo000
Captain Obvious
Super User
Imo000's Avatar
Count the holes in the chain (where the sprocket teeth would poke through) and not the bump and 13cm = 130mm.
Old 12-31-2012, 11:02 AM
  #167
Want to be
Want to be's Avatar
Bent valves status:
Regretfully, i am in the middle of the road. I do not have a high capacity compressor. I will re-install the Camshaft and then button her up to confirm if anything was bent. My next step would be to use a compression test. I realize the best choice is a leak down, but i can't do it. While its a little extra work, its not going to cost me anything except time.
Links advise:
Thank you everyone. I am still considering the turbo chains but for now i need to get her button up to see what type of damage i will be in soon. My fingers are crossed and the great Kris-ken is on my hot dial number.
Old 12-31-2012, 11:05 AM
  #168
SeanR
SeanR's Avatar
Originally Posted by mark928gt
Leon mentions there are seven links and 13cm between the "notches" on the cams. I just aligned my cams using the information from Big Dave's 928 Page. If I count the links that line up with the bumps (I don't have "notches") on the cams I get seven links. Between the cams I get five links and 113mm, not 13cm.
Also, my new turbo chains don't have colored links. I don't think it matters as long as the alignment of the cams is correct and the correct number of links between the bumps is achieved.
Can anybody confirm if the 113mm or 13cm is correct?
Yes, 113mm is the correct measurement from tip to tip.
Old 12-31-2012, 12:20 PM
  #169
FredR
FredR's Avatar
Originally Posted by Want to be
Bent valves status:
Regretfully, i am in the middle of the road. I do not have a high capacity compressor. I will re-install the Camshaft and then button her up to confirm if anything was bent. My next step would be to use a compression test. .
After my accident my S4 motor had two bent valves on cyl 7, nothing grotesque, no noticeable mark on the piston other than a bit of carbon chipped- no compression pressure whatsoever.
Leakdown test is more to determine excessive wear that a compression test does not reveal.
Regards
Fred
Old 12-31-2012, 12:41 PM
  #170
Imo000
Captain Obvious
Super User
Imo000's Avatar
Regards
Fred
That's no so. A leakdown test will do the same as a compression test and much more but without the need to rotate the engine. Once you do this, you'll understand why is it supperior to just a compression test.
A small rented compressor would be enough to test this engine.
Old 12-31-2012, 12:46 PM
  #171
AO
Supercharged
AO's Avatar
A leak down test will also tell you if it's intake valves, exhaust valves or both or neither or something else like rings or cylinder wall damage.
Old 12-31-2012, 01:45 PM
  #172
auzivision
auzivision's Avatar
I'm guessing there is a pretty good chance his valves are fine and following is my reasoning. The timing belt was intact and where it should be before disassembly. Also, the way the cam tip broke it wouldn't let the cam gear slip prior to removing bolt.
@ G8RB8... are you suggesting that without the cams in place, all the valves should be shut and therefore all the stems should be sticking through the same distance? While maybe not a perfect test, that seems like any easy thing to check at this stage.
Old 12-31-2012, 02:25 PM
  #173
FredR
FredR's Avatar
Oh really? I guess I must have dreamed what I saw when I found no compression on number 7 and then two bent valves in it! The lad said he had no leakdown test capability- he will find a bent valve with a compression test. One assumes he has the nouse to turn the engine over manually before trying to crank it for a compression test to ensure nothing is blocking motion.
No one said a leakdown test was not better- read the small print!
Happy New Year.
Fred
Old 12-31-2012, 02:59 PM
  #174
Want to be
Want to be's Avatar
For now, i have gotten my self in a predicament with a striped star head. I really don't want to grind this one off. I can't imagine how much junk will drop in side the camshaft housing. I have highlighted the NG bolt in red below. Before starting the bolt looks like it had been touched. I am wondering if the cam shaft has been removed. Either way, anybody have a good idea? I do not think they make 9mm star bits. I do not have a drill to fit this tight of space. If i drill the head off, will i be able to back the screw out?
Old 12-31-2012, 03:10 PM
  #175
G8RB8
G8RB8's Avatar
yes
Old 12-31-2012, 05:07 PM
  #176
Want to be
Want to be's Avatar
Question, the bolt i had striped, connected to the tower. Is the tower a brass substrate? I'll check with my magnet later to see if it steel. Unless someone might have another idea, i guess i am going to need to grind the bolt head off. My mechanic friend mentioned taking a punch and taping it into the bolt head. I'll try this first but i am pretty much thinking this will not work either.
Old 12-31-2012, 05:34 PM
  #177
rexpontius
rexpontius's Avatar
How badly stripped is the bolt? You can try to spot weld a cheap bit onto it and then extract the bolt.
If it is not very badly stripped you can try to put some ezGrip paste on your bit, you'll be amazed how good that stuff works.
Good luck
Cheers
Old 12-31-2012, 06:06 PM
  #178
Leon Speed
Leon Speed's Avatar
The bolts are on there pretty tightly, I tried to remove one once by wacking it with a screwdriver on the side but had to resort to using the dremel to cut the head in two, the bolt turns freely once the tension from the head is broken. Besides, the mounting area might break when using a hammer. Need to cover everything really really really well, e.g clean off all surrounding oil and tape the area off, use a large blanket so you can lift it off completely once done. Also consider using a shopvac close to the head to suck up all filings while cutting.
Old 12-31-2012, 06:09 PM
  #179
Want to be
Want to be's Avatar
Its toast. I thought the 12 point bits were stronger than other head bolts. Weld idea is great but I don't have access to the equipment.
Old 12-31-2012, 06:17 PM
  #180
Imo000
Captain Obvious
Super User
Imo000's Avatar
Happy New Year.
Fred
Before going off the deep end again, make sure you fully understand what I wrote.
Quick Reply: I might just cry (belt tensioner warning)
