I might just cry (belt tensioner warning)
About a mile away from home i noticed my timing belt light turn on. My first thought the car was running fine and it was a false alarm due to the OS temperature. The car then began to make a weird chatter noise, i then decided to turn her off.
I called a wrecking truck and her taken home. I don't know the extent of the damage but i would guess i have some bent valve. Go figure, my winter project was to replace the timing belt.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
It sounds like it was still running OK when you shut it off. If that's the case I doubt you have valve damage, since it wouldn't be running if the belt actually broke. Something has obviously gone awry in the front of the motor so you need to pull the front covers and see what's up.
What year is the car? Not all 928 cars bend valves if the belt slips or beaks. If the belt does slip or break, the car would likely not even run. Check the belt rollers for bearing noise. Check the tensioner & connector to it.
I called a wrecking car and her taken home. I don't know the extent of the damage but i would guess i have some bent valve. Go figure, my winter project was to replace the timing belt.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
You did the sensible thing in the circumstances but like Charley said do not torture yourself suspecting the worst until you have diagnosed the problem [whatever it may be]. If the belt had snapped you would have known about it immediately- that a strange noise suddenly appeared whilst the engine was still running is bound to be worrysome.
Get the cambelt covers off and have a good look in there to see if you can spot anything obvious.
Good luck
Fred
But a non-fatal de-tensioning-- with new noises-- is most likely the water-pump bearings failing. The first step is to pull the covers and see what you've got, it's not a big job. Distributor caps, crank pulleys and belts, front engine harness, and some other bits-- no big deal. There are some good write-ups out there.
Please post some pic's of what you find.
From Phil's signature, I would say that it is a '87 S4 with 236K miles. Definitely an interference engine.
It's an 87 S4
Tb needed tighten per the owner but had been changed.
The started to make some noise and I was afraid to press the gas pedal and shut her off.
Yes. I'll post what happen
Ifs it's the valves, I am sure I can get a friend to help me replace or repair.
The car was going down for the winter.
That was a sign of likely troubles to come, TB's do not need tightening unless something in there is failing.
The good news is that if the engine was running when you shut it off, then-- as mentioned above-- the belt did not jump timing and the valves are probably fine.
This is one of the best write ups on doing the TB/WP. Shows what comes off & when with lots of pics.
http://dwaynesgarage.norcal928.org/1...0Procedure.htm
Captain Obvious
Super User
Super User
I was able to spend five minutes on the car today. Anyways the inspection window of the belt on both sides displays an intact belt. My mechanic friend said it was likely the belt skipped a tooth. In the cold weather the belt becomes hard and if it is loose, it could have skipped a tooth. I asked him how many teeth can the car skip. He said maybe one but he was not sure since he has never worked on a 928. 944's he has though
If it's loose enough to jump teeth either something has broken in the timing belt assembly (roller/bushings/etc) or you would have been getting a warning much sooner. I'd pull the passenger side cam gear cover and check the tension of the belt properly. Until you actually get in there and look at it, everyone is just guessing what has gone on.
Have your mechanic pull both cam gear covers, set the engine to Top Dead Center (TDC) and then measure. If all three spots can be set to TDC then you've not skipped any teeth. Try this first and then report back to us.
My car jumped timing this morning on the way to work. I ran/ walked a mile to work. I arrived on time only because I left to try to get there early. Thank god for non interference sixteen valve motors. It's time for a tensioner and belt.
*edit - As far as running with a skipped belt, yes, it will run. Mine would idle incredibly bad and incredibly lean. My wideband was showing 22.4; 22.4 is what it reads in open air. I had fuel pressure, and my injectors are brand new. It will not have any power, and it will probably die if you even touch the gas.
I'm sure my belt has slipped because I had just downshifted, did a pull in second, and upon shifting to third, the car just coughed up a lung. I imagine the belt got pulled taught, then slackened when my rpms dropped during my shift, and it allowed the belt to slip.
I have had every accessory belt on my 928 engine snap because one was lose. The same thing happened, I was revving the engine, the belt(s) got pulled tight, and when I let off the gas, the slack threw one or more of the belts off, and it took out the others with it. I have a dent from the inside of my hood outwards, because I had no hood pad. The snapped belt slapped the underside of my hood, and it even knocked a big chip of paint off.
I was able to spend five minutes on the car today. Anyways the inspection window of the belt on both sides displays an intact belt. My mechanic friend said it was likely the belt skipped a tooth. I guess in cold weather the belt is hard and if its lose it could skip a tooth. I asked him how many can the car skip. He said maybe one but he was not sure since he has never works on a 928. 944's he has though
Also if the belt has stripped teeth,everything will still look normal through the inspection ports. Do NOT try to start the car because you think the belt looks ok from the back.
