928 Forum 1978-1995
Sponsored by: 928 Specialists
Ebay SC kit
Old 07-30-2012, 02:42 PM
  #106
victor25
victor25's Avatar
I was calling for your address info to send you the t's, plugs, and your new cool air inlets. PM me your info when you get a chance.
No crank case vacuum pump is needed!! You just have to install the correct ventilation.
Old 07-30-2012, 02:45 PM
  #107
Lizard928
Lizard928's Avatar
Let me know when you're getting closer to doing it.
Originally Posted by SeanR
I'll take them, won't be able to get to it until next week though.
Thanks.
Old 07-30-2012, 03:35 PM
  #108
Bill Ball
Under the Lift
Bill Ball's Avatar
Isn't the dipstick tube ABOVE the oil level, especially when the motor is running at high RPM and oil is packing in the heads. How does oil shoot out the dipstick tube under those conditions?
Old 07-30-2012, 03:38 PM
  #109
SeanR
SeanR's Avatar
I was a little bit full on the oil. That was my first though too is "how the hell did that happen" so after it sat over night I took a look and yea, a bit over filled. Besides, when that is the only place the pressure can vent from, it's going to have oil going with it too. That crank can toss some oil around.
Old 07-30-2012, 03:39 PM
  #110
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by killav
Sean,
This line will need to come off and get plugged if you haven't already done so. It will pressurize the crank case. I am using this line to feed my boost guage inside the car.
Edit: If you want to keep this line to help seal the rings during cruise and idle, then you can probably get one of Herman's check valves and finaggle a way to put it in-line with this hose.
This line is also a vapor recovery line going to the gas tank. In one boosted car it inflated the gas tank.
Old 07-30-2012, 03:50 PM
  #111
victor25
victor25's Avatar
Bill, There is a electronically controlled valve on the end of that tube. Signal comes for the LH to control that valve, and how it opens and shuts? I was told that it opens under idle and closes when your the car comes off idle. Can anyone confirm that???
Old 07-30-2012, 04:10 PM
  #112
Cosmo Kramer
Cosmo Kramer's Avatar
I removed that vent from the intake and plugged the intake port. I left the valve active and ran a hose off it and let it vent to the atmosphere under the car away from the engine bay. Has worked fine for 2 years on my car, no gas smell in garage, no pressure/vacuum in the tank ever.
Old 07-30-2012, 04:14 PM
  #113
victor25
victor25's Avatar
That guys diaphragm valve by the charcoal canister must have been bad. It should only be open when there is vacuum applied to it, and their is no vacuum to it when the throttle is open and especially when boosting
Old 07-30-2012, 04:18 PM
  #114
victor25
victor25's Avatar
Just confirmed on my car.... no air can can pass through the Diaphragm under pressure only under vacuum. But I would still like to know exactly when the solenoid valve opens and closes.
Old 07-30-2012, 04:49 PM
  #115
17prospective buyer
17prospective buyer's Avatar
Kramer, nice solution to simplify the tank ventilation, for those of us that aren't tied up with emissions BS. A sort of road draft tube for the gas tank LOL.
With regards to my crankcase ventilation post; wouldn't using vacuum to vent the crankcase be the simplest/easiest solution if you position the port that will be a vacuum source at a place high up, as well as use a filter/separator for the suspended oil that is in the vapor.
You would still need to find a way to ventilate the heads though right?
I know i usually look like a totally dumb idiot on here... but i like to learn.
Old 07-30-2012, 05:01 PM
  #116
928mac
928mac's Avatar
Venting can be done on the up side of the compressor like at the airfilter box. There will be vacuum in the box
Old 07-30-2012, 08:23 PM
  #117
17prospective buyer
But that doesnt do anything to reduce carbon build up and detonation... Lol. Plus you then have oil entering said compressor.
Quick Reply: Ebay SC kit
