928 Forum 1978-1995
Sponsored by: 928 Specialists
Ebay SC kit
Old 07-28-2012, 10:17 PM
  #91
soupcan
soupcan's Avatar
Originally Posted by SeanR
I'm not doing it out on the driveway. It's 104 today.
Wait for it......
Wait for it.......
Old 07-28-2012, 10:50 PM
  #92
Imo000
Captain Obvious
Super User
Imo000's Avatar
Is your crancase ventilation system still stock?
Old 07-28-2012, 11:21 PM
  #93
Lizard928
Lizard928's Avatar
Time for a vacuum pump.
Old 07-29-2012, 12:06 AM
  #94
jcorenman
jcorenman's Avatar
Originally Posted by victor25
Sean.... Sounds like the "Bernoulli's" line of thinking that someone talked you into is not working. On Monday I will send out the vent T's and plugs you passed on. Thanks for being a Ginny Pig though... LOL.
Bernouilli's don't work so good when it is 6psi inside and atmospheric outside...
Sean, I've got some LC-1 plug-in kits made up, do you still want one?
Cheers,
Old 07-29-2012, 12:13 AM
  #95
SeanR
SeanR's Avatar
Cheers,
Yes Jim, still needing one. Roger has the WB02 in stock so I just need the LC-1. Also, do you have any 87-88 ST cords in stock, need one if you do. Just let me know where to send the munee.
Old 07-29-2012, 12:15 AM
  #96
SeanR
SeanR's Avatar
Yep. Have a Provent on the way and various parts to make something up.
Old 07-29-2012, 02:27 AM
  #97
jcorenman
jcorenman's Avatar
PM sent!
Old 07-30-2012, 12:29 PM
  #98
killav
killav's Avatar
Default Crankcase pressure
Sean,
This line will need to come off and get plugged if you haven't already done so. It will pressurize the crank case. I am using this line to feed my boost guage inside the car.
Edit: If you want to keep this line to help seal the rings during cruise and idle, then you can probably get one of Herman's check valves and finaggle a way to put it in-line with this hose.
Old 07-30-2012, 01:28 PM
  #99
17prospective buyer
17prospective buyer's Avatar
Couldn't you use the air pump as a vacuum pump for vapor scavenging? Isn't that the most prime solution for the 928 ventilation (or lack of) system? Wouldn't you have to tie in a catch can/separator between the ventilation lines and pump?
Old 07-30-2012, 01:39 PM
  #100
victor25
victor25's Avatar
Sean
Mike is correct, that needs to be plugged. I believe we plugged this when we were doing the install, but check it to make sure we didn't forget it.
Old 07-30-2012, 02:22 PM
  #101
SeanR
SeanR's Avatar
I pulled and plugged the rear valve cover breather hose this morning before going on a nice 50 mile drive and have nothing in the catch can. I'll plug that one to for giggles later........after it cools down, like around midnight.
Victor, I missed a call last night, was it about this stuff?
ETA:Just plugged that one up, will see how it goes. Thanks guys.
Old 07-30-2012, 02:30 PM
  #102
Lizard928
Lizard928's Avatar
The factory airpump will quickly fail with oil entering it.
It is designed for fresh air only.
You really need a proper vacuum pump like one from GZMotorsports.
Old 07-30-2012, 02:35 PM
  #103
SeanR
SeanR's Avatar
Originally Posted by Lizard931
17,
There are several way around that and are currently running as prototypes around here. Sadly, I have the PK tensioner with out air pump bracket so I will end up going with a unit like you are talking about.
Old 07-30-2012, 02:37 PM
  #104
Lizard928
Lizard928's Avatar
I can send you some Solid works files to make that install easier.
Old 07-30-2012, 02:38 PM
  #105
SeanR
SeanR's Avatar
I'll take them, won't be able to get to it until next week though.
Thanks.
Quick Reply: Ebay SC kit
