928 Forum 1978-1995
Sponsored by: 928 Specialists
New Crankshafts
Old 02-18-2012, 12:18 PM
  #121
John Speake
John Speake's Avatar
You would need a new design block with different (wider) offset between cyl 1-4 and 5-8 ?
Originally Posted by Imo000
I was starring in my garage at a left over crank, from a Nissan 3.5 V6 tonight and looked different than the normal V6/8 cranks that I've seen in the past. At a closer look it dawned on me that each connecting rod is seperated by a counterweight and they are not paired up like a normal V6/8 engine.
Greg, I'm sure you've seen this before but what are the benefits of a design like this and would a crank like this could be of any benefit on a 928?
Old 02-18-2012, 12:24 PM
  #122
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Gosh Greg! A new crank, and now a new avatar and an image in your sig file, as well as, a small business membership. This could tilt the equilibrium of the 928 universe.
Old 02-18-2012, 12:26 PM
  #123
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,747 Likes on 1,335 Posts
Next thing you know, there'll be an espresso machine in the front office.
Old 02-18-2012, 12:29 PM
  #124
S4ordie
S4ordie's Avatar
and implementation of a new dress code; long pants required and no facial hair.
I'm worried Greg, should I be?
Old 02-18-2012, 01:39 PM
  #125
SeanR
SeanR's Avatar
He even updated his Facebook page a couple weeks ago. I'm feeling a disturbance in the force.
Old 02-18-2012, 02:35 PM
  #126
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
Yes, I'm actually finishing your engine, too!
I came back from my "Birthday Week in Yosemite" mentally recharged and ready to go...now if my knees and back would get the message.
Old 02-19-2012, 02:24 AM
  #127
brutus
brutus's Avatar
The Nissan is a 60 degree V not 90 plus to be smooth it fires every 120 degrees. For that spacing it needs 6 individual rod throws. The normal V-8 is 90 degree V and pair up two rods on each throw. Many early American V-6s were 90 degree V-8 simply a V-8 with two cylinders missing. Created what was called an oddfire because of the missing beats of the no longer present two cylinders and was quite rough running. Even fire cranks with offset corrected the firing order sequence to sound better but then ran as two three cylinder banks with all the imbalance and harmonics of a straight three.
So the answer is no benefit at all for a 928 V-8 even if it were possible.
Old 02-19-2012, 01:17 PM
  #128
Imo000
Captain Obvious
Super User
Imo000's Avatar
Thanks, I learn something new every day.
Old 02-19-2012, 03:31 PM
  #129
Iwanna928
Iwanna928's Avatar
If these parts go for 6500 and you had a 5.0l shortblock what would a ball park figure be in putting it together with custom pistons. Pistons are around 2k give or take.. machining work etc etc what would you think for it to be all put together and ready to go?
Old 02-19-2012, 03:47 PM
  #130
IcemanG17
IcemanG17's Avatar
if you have to ask
I think its around $2k to over bore the block for 104mm pistons....then figure about double the parts price in labor....so $8500 labor + $8500 parts...
Old 02-19-2012, 04:32 PM
  #131
Iwanna928
Iwanna928's Avatar
Thanks Brian. Think I will need something like this for my Euro!
Old 02-19-2012, 06:08 PM
  #132
BC
BC's Avatar
One could get a 5l quite close to 400 with higher compression pistons and some nice cams. Then run it up past 7k safely.
Old 02-19-2012, 07:25 PM
  #133
Imo000
Captain Obvious
Super User
Imo000's Avatar
Isn't this a little too optimistic?
Old 02-19-2012, 08:10 PM
  #134
Iwanna928
Iwanna928's Avatar
A 5.0l with stock pistons like Greg is working on is a viable choice.
5.0l screamer put down some healthy numbers.
A 5.0l euro with some custom cams would be sweet. Save you the cost of custom pistons and boring the block.
Would be a healthy street car. Certainly enough power for me.
Time to start saving. Save half the money and sell the OB and there you go!
Old 02-19-2012, 08:23 PM
  #135
Rob Edwards
Archive Gatekeeper
We haven't seen Greg's 5L crank yet. The setup that I think has the greatest potential as the basis for a 20-year 'refresh' and as the canvas for additional modding centers around Greg's new 78.9 mm (stock stroke) 5L crank. So $6500ish for crank, rods, rod bearings, main bearings, and piston pins.
Assuming the bores and piston skirts are good in your '85-'95 5L long block, on top of Greg's supplied bits, you could just re-ring your 100 mm pistons ($300ish a set for rings), deck the heads and install new valve guides (maybe $1K in springs/guides/stem seals/lightweight lifters and $1K in machine shop work), get Greg's rec on proper valve springs and installation height to work with whatever cams you pick (figure $1800-$2500 for cams), $700 for an ATI damper, and $600 MSDS headers. Add another $1500-ish for pan spacer, windage trays, an improved crankcase breathing setup, and ministarter.
I get to roughly $14K for all of that. Plus all the ancillary gaskets/hoses/sensors/PEMs, and whatever additional labor is involved in actually assembling everything. But this would be a heck of a 5L screamer, given the right cams. Dunno about 400 wheel hp, but I bet you'd get to an honest 330-340 whp with the right cams and sharktuning. Might touch 400 at the crank.
I don't know diddly about 16V engines- what is the maximum 'real' whp anyone has seen out of a normally aspirated Euro S (or whichever) 16V engine?
Quick Reply: New Crankshafts
