New Crankshafts
Basic Site Sponsor
Basic Site Sponsor
New Crankshafts
Thought you guys might enjoy a couple of pictures of 928 high performance cranks being built. I've learned a bunch, since I "tore" up all the old blueprints for my stroker cranks and started over.
Making a crankshaft from a chunk of raw material isn't a "ten minute" job. It is very involved and very difficult. It requires a lot of separate machine operations....on an entire shop full of different kinds of machines.
Here's a picture of a cart full of 928 cranks just back from the first heat treatment. They are hardened to "around" 40C at this stage. They started out as a solid chunk of very special steel. They are getting ready for the oiling holes to be drilled. All of the rod and main journals are "roughed" to size. Basic counterweight shape and size is aready roughed in. Holes are drilled and tapped.
Here's a picture of one crank mounted on a simple milling machine, getting the position for the oiling holes marked. I took this picture, because you can see the basic material that the cranks start from, on the ground behind the mill.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Site Sponsor
Basic Site Sponsor
Regardless, the journals are just "roughed" in. They have been ground, but not on a "finish" grinder.
I was there to check/adjust the size of the counterweights with my "new" rod design. The rods fit onto the crank, without the bearings, so I'd guess that the journals are about .050" oversize, at this point.
Basic Site Sponsor
Basic Site Sponsor
Most "high end" crank builders will not make a crank, these days, with 8 "full" counterweights, unless the customer insists. Just a bunch of "extra worthless weight" slinging around, inside the engine. I talked to Whitey at Moldex, ten years ago, about adding two more counterweights to my 6 counterweight crank and he flat told me that this would be "stupid", considering the rpms these engines were turning. However, current camshaft, intake, and head design has "added" the ability to "twist" the 928 engine to higher rpms...which requires different thinking.
Anyway, 8 full counterweighted cranks are pretty "old" technology. Keep in mind that the GTS cranks were designed more than 20 years ago!
Stop and think about how far engine design has come, in the past 20+ years!
As I mentioned, these cranks are absolutely "new" in terms of design. Of course, the length and the basic rod and main bearing location doesn't change...but certainly, everything else has.
If you are needing test subjects, I can send you my car.
Well, as Fabio's avatar says in the previous post,
........... is like a hot stripper. I just keep throwing money at her and hope that someday she will give me the ride of my life......
Same sentiment here
