928 dual disc release bearing available again!
Mark
do you have pictures or a diagram as to how the different parts go together so I can tell where to press to pull the release bearing apart? I ordered a replacement bearing from Roger but I am not sure which pieces need to come apart. It looks to me like there are 4 seperate pieces that make up the release bearing (includung the bearing itself). Is this right?
The Parts Whisperer
I do not any here to take pictures of at the moment as all my cores are out but when I get one in I will post some pictures. It presses apart very easily.
Basic Sponsor
Jim,
You just sit the bearing with the center tube pointing upwards and press it out of the housing. Press the new bearing and center tube in and replace the cover - really easy.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Just talked with Roger and got it figured out. There are actually 4 pices including the bearing but the very center tube portion with the snap ring groove comes with this replacement bearing, so the only parts that need dissasembly are the release bearing cover and the bearing assembly. Very easy solution to a no longer available part. Thanks to all the vendors for coming up with solutions to problems like these.
DougM posted some pics of the throwout bearing removal here: https://rennlist.com/forums/928-foru...o-bearing.html
Hi Roger ,
release bearing is Ausrücklager in german.
http://www.daparto.de/Teilenummernsu...#gotoBestOffer
Here´s the link.
The user ordered the part in this shop for ~200
http://www.mittelmotor.de/webshop/deutsch/mm.htm
Here´s the link.
