Lightweight Starter - Any Interest??
#46
This starter was developed to resolve those issues as well as using a motor with the proper torque and higher RPM than previous starters.
#47
Captain Obvious
Super User
Super User
#48
Archive Gatekeeper
It ends up being the lowest point on the car....oh it also won't clear headers of any kind....
#51
Archive Gatekeeper
If I can squeeze a sheet of fiberglass between the two....
#53
this new starter resolves both of those issues.... moves it away from the headers and removes the stud from being the lowest part of the car.... that is why I never would install one of those other starters....
#54
Archive Gatekeeper
Since I'm half way to the 10K mark on this motor, if the new one will work with a pan spacer, I'm game to try before this one goes TU.
#55
Basic Sponsor
A new starter has shipped today to one of my customers who has a pan spacer fitted - wait and see for the feedback.
#57
Archive Gatekeeper
They're made around a lot of things, there was a whole engine/crossmember/rack jig/mockup. Amazingly, no clearancing had to be done on that #5 tube.
Roger, I will look forward to hearing about the outcome RE: the spacer. The IMI is REALLY tight with the bottom of the pan, it requires a trick upper bolt to mount it.
#58
Rob, that is what I assumed. What I recommend for a pan spacer install is the lower bellhousing that you have that has the integrated starter bracket. Countersink the top bolt with a 45 degree bit, and then use the correct countersunk bolt. Install the starter to the lower bellhousing and then install the belhousing. The top bolt if you used a regular one would require clearancing on the pan....
#59
sure it can.... then it is pointed down, and too low. It ends up being the lowest point on the car....oh it also won't clear headers of any kind.....
dont thing either mark andersion, Fan or I have had any issues for the many years we have used the little starter. Ill post some pics if you want.
#60
Basic Sponsor
We now have the starters in stock for those that expressed an interest.
I send one to a customer to fit with a pan spacer but have not had any feedback as yet.
Also sent one to Greg Brown and will be keen to see what he has to say.
