Carbon/carbon clutches anyone?
#61
I recommend what Hacker said over an aluminum one if you just want a DD. The stock steel flywheel is so good and it's weight is trivial. Aluminum brings the risk of having cheap crap materials being used in the wear surface.
#62
Archive Gatekeeper
Marc- Greg and Rob at RPS have been working on this setup for several months now.
RE: replacing a DD setup, I'm replacing a 'stock' DD setup (only non-stock bit was an upgraded pressure plate) with a 60-2 ring on it, so this will bolt right up. It uses a hydraulic Tilton release bearing, so you do need to put a hole in the side of the bellhousing, and the bleed line runs out the old release arm opening. Greg wanted to be completely futureproofed against limiited supplies of Sachs pieces. The only factory bits left are the timing ring and the intermediate shaft.
Louie was kind enough a few years back to loan me his jig for aligning an S4 timing ring on an 85-86 flywheel:
#63
Administrator - "Tyson"
YES!!!!
Wait a minute......you mean they are supposed to go on a certain way? That would explain my rough idle.....
Oh I'm kidding......
#65
No, the early flywheel is a tad bit smaller, I found out the hard way. I thave three S4 auto rings and five 78-84 flywheels....no go.
One could try to weld them together. When my local metal master Todd said: "I wouldn't if it were my car" I decided to just get the correct parts - 85/6 flywheel.
I'm sure Mark Anderson has a pile of them. S4 automatic flywheels are not in much demand
#69
#70
Archive Gatekeeper
Got the clutch installed yesterday with the Tilton TOB, got it plumbed, everything operates nicely! Just gotta button everything up now....
#72
That's really nice! How did the rest of the plumbing go? did you have to remove the bell housing to cut that hole? i wonder if a Throwout like that could be used on a DD set up... :-P
#74
Former Sponsor
I originally designed this clutch to be a pull clutch, but changed the design halfway through the process, when I realized how tough getting stock pieces was getting to be....especially the T/O bearings.
Like Rob said....the only thing stock that this set-up uses is the central clutch shaft.
#75
Former Sponsor
For that matter, once the clutch is removed, the torque tube virtually "jumps" out of there, too.
